6n2 GTi Belts
Hi guys, I'm watching some seatbelts on ebay and the advert states 'no pretensioner' is this as standard or have the belts been modified for some reason?
Noob question i know but i really have no idea :)
  • Replies 8
The pre-tensioners are fitted on any car that has an airbag, so I'm guessing there from a non airbag car?? or have been diasbled in some way, if it's the later I'd steer clear of them as any modification to the belt reel might not make it work in a real emergency!!
There are two types of pre-tensioners that are used on the VAG cars, purely mechanical and the other electrically controlled by the airbag control unit
Ahhh okay I thought as much! They are the red seatbelts from a GTi so it would have an airbag
Thanks for the quick reply :)
In that case they should definately have a pre-tensioner on the belt reel, either the mechanical unit or the electrical if the seats had side airbags, so I'd message the seller to find out what's been done to them!!
I think it would just be the mechanical unita as to my knowledge, i dont have side airbags. My suspicion is that the car they were taken off has been involved in an accident triggering the mechanism? In that case they have removed it i assume?
Don't really want anything involved in a crash in my car (bad juju and that ;) )
If they are from a crashed car and the tensioners have "fired" it renders the belts useless, I know I've got one here that I accidently set off the mechanical tensioner
Ahhh i see, in that case I think I will leave them alone. I have messaged him earlier asking some questions so we'll see what he says as reasoning for this.
This was the response i got:
Any thoughts?
Looking at the pictures they look like they have the electrical pre-tensioner
This is a picture of a belt unit from a 3 door Ibiza cupra I have and there is no obvious tensioner unit just the connector for the airbag controller.
You'll need to check your belt units to see if they are the mechanical or electric units, if they are the mechanical then the red ones would'nt fire off in the event of an accident, without doing a rewire job and a new airbag ecu :-(
