please delete
I'm getting the car sprayed again , but want the windows out , is it difficult to remove the tailgate window ? What is needed to do it ? Does it need new seals ect ?
Edited by dart_strife
  • Views 838
There is no seal as such as the rear windows bonded on with what i assume is some kind of tiger seal. Just need to be able to get between the glass and the bootlid with a thin sharp object and cut through the sealer. id guess a thin piece of sharp wire would do it (well that would be my first plan anyway!)
Sounds like an idea , then a matter of sealing it up ? Just along the bottom is it sealed ?
Uhh its bonded all the way round I'm pretty sure, best leaving it to pros because I don't think its particularly easy
