Minor problem or major problem? Help! :(
Okay so I bought a Polo back in April 2012 which had been in a low speed collision so had some damage done to the front of it. I bought it regardless of the airbag light being on and there being a massive rectangle cut out in the dash... Stupid, I know. But it's a 2003 with 40k mileage.. And it was advertised at £1000! I was impatient, wanted my first car RIGHT at that moment, and all that jazz :( But aye, I bought a new dashboard and got that fitted back last May, but the airbag light is still on. I didn't work until March this year so I've now decided to get the car up & running. I began by getting a diagnostics test to try get rid of the light if possible. That didn't happen and I was told a lot of stuff I kind of err, don't understand! The mechanic guy wrote down the fault codes on a bit of paper so I thought I'd write them here and try get more of an understanding on what it'd cost to fix each of the problems listed..
65535 - ECU defective. unknown sub code
00654 - seat belt tens(?)... his writing is bad :(
00655 - resistance too high +short with ground (?)
00532 - supply volt B+ signal too low intermittent (poss clock spring)
I genuinely haven't a clue what any of this means.. help!! I don't know whether this is worth fixing or not. I only earn £500 a month and pay out a lot already.
The car also needs two front tyres, a back box and a battery. It's been sitting on a driveway for ages and the last MOT advisories say that my front brake discs were pitted. I'm assuming I'll also need front discs & pads.
I don't know if this is too much bother or not. I need opinions. What would you do??
  • Views 1.7k
First of welcome to CP
When you replaced the dash did you also replace the passengers airbag? (hole in the dash)
The first of those codes could be either the airbag ecu has partially died or combined with the last code be a power supply problem (flat battery) and the ecu needs to be re-coded to the car, the other two codes refer to the seatbelt pre-tensioners/wiring, a couple of weeks back there was another posting from someone with a 9N (similar age to yours) who had found damaged wiring under the carpet for the drivers seat and that was throwing up similar codes and after a rewire it was all working OK
I'd get it going again, but that's me.
You're in Scotland, and I'm breaking my Polo - so if you want a cheap battery, mine is yours for £15. Used, but it'll get you by!
So, from the top.
The airbag has been triggered - so I don't know if that means that the ECU is now burst, either way, it's usually tucked in behind the centre console (where the heating controls are), on the floor.
Can maybe see it if you get onto the passenger floor and try and peer through there. 4 bolts, straight swap. A scrapyard will have one for a tenner, and it'll take you 5 minutes to fit.
The tensioner on the seatbelt might have triggered because of the accident, so you'l need a seatbelt. Again, scrappy - £20, if that..
Just checked the codes: 00654 and 5 mean passenger and drivers resistance too high. Could just be because of the airbag ECU needing replaced, or two new seatbelts.
Supply voltage will be because the battery has went flat at some point in it's life.
So, new airbag ECU, maybe seatbelts, and a battery.
If you need a hand with fitting, feel free to PM me dude! :)
Thanks for the welcome! Although I made this account due to my old email address being hacked:( So I've actually been on here for a year now haha!
And hmm, is that a big job though? I don't really earn enough to go about splashing hundreds of pounds on this car >.<
Does it need coded Nige?
The 6n2 was a straight swap?
When any airbag is triggered in a car the ECU has to be replaced as it goes into a lockout/safety mode... You cannot do anything to the ECU to sort it other then replace it, then you need to put it on bacon and tell it it has a new ECU and the light should then go out.
Can't remember if the tester at work said it was already in or not, but airbag light in is a MOT fail (or soon to be, can't remember which)
Edit: my iFail auto corrected vagcom to bacon :lol: but il leave it for the fun of it :lol:
Edited by matt01
Must admit, I laughed at the bacon bit..
Yeah the airbag light is now an MOT fail :( That's the only reason I want to get it away! I would ignore it otherwise haha.
There's a section in Elsawin about "Adapting a replacement ecu" but it does'nt go into any details :-(
