mk2 rear valance
Has anybody ever fitted a new rear valance to a mk2?
I just need to know if i could do it myself or if it's a definite bodyshop task.
Cheers!
I've done it definately needs welding mate so its whether you can do that or not as they line up pretty well and you would just mark up where the new one will fit upto and cut the old one out
  • 8 months later...
Is it possible to remove the the spot welds? or would you have to just chop it just under the spot welds?
spot weld drill bit is your new friend :)
