Options...And I need everybody's help on this!
Alright so I've had my Polo now for 6 months and had various trials and tribulations with it and yesterday the clutch finally decided to give up the ghost. The MOT is also due and I was out to get bits (luckily hadn't got there and spent money!) and for the MOT I know that it needs back brakes (I'd booked MOT early so I knew what I'd need to do).
To do list for the MOT:
Back brake shoes need replacing
Brake pipes need replacing
Handbrake needs adjusting
High emissions (Possible o2/Lambda sensor failure)
Because of the clutch going I'm going to need a new clutch obviously which I shall do in the next couple of weeks. Now with the brakes I have a general HATRED of drum brakes, I hate them with a passion, they're crap for stopping, overheat easily, they're a pain in the a*se to replace/adjust and are generally outdated crud!
So I'm going for disc conversion at the back but I'm unsure on which setup to use whether to go for Polo GTI setup or Golf GTI setup or even the Seat Leon setup...What are the differences and is there any advantage to the model?
Also in the *Not too distant* future my engine is getting tired (1.0 AER on 112k miles) so I'm going for a 1.4 when time and money frees up but which one? 8v or 16v? It will be on bike carbs when I do the conversion but to run the engine what bits do I need? besides obviously the engine/box and ECU?
Anybody that can help me with my questions will be a jolly good chap in my eyes and will be thanked accordingly!
  • Views 561
sell it , buy a 16v 1.4 or gti, fit discs on rear,
With a fucked clutch, a rusted bonnet and about 3 days left on the MOT it's not worth a penny. I want to use it as a project, why would I want to go out and buy one that's already been done?
You'd be better of getting a shunted or MOT fail GTI. Use the axle off it and the engine out of it. Plus all the other nicer bits you don't get on the lower spec models.
