please delete
What mm thickness steel should I buy for repairs on the mk2f polo floorpan ?particularly at the jacking points ?
Edited by dart_strife
  • Replies 10
  • Views 1k
As thick as you can get really at least 1.2mm for strength an ease of welding without blowing through so much
Closest to original as you can, if its too thick it won't flex with surrounding panelwork and the immediate surrounding metal will be open to fatigue. Weld alone can cause this too, so try and get the weld down fairly flush with the panelwork. That way, any flex will spread evenly and prevent fatigue.
Not such an issue on areas that don't flex, like sills. But its something to keep an eye on in floor pans etc.
I'm sure the standard floor pan uses 1.2mm that's why I said it
I have cut all mine out and scrapped it maybe I should of offered it on here for people to have proper repair sections
So u replaced you are floor pan Pete ? Pic ?
what section do you need I have a complete pan that I can cut
I want jacking points , mine are rusted ect, are the ones you have unscathed?
I haven't replaced mine yet but the old one is all cut out
No body got the jacking points in good condition then ? Pics ?
pm run forest?
I made new jacking points for mine and integrated them into the frame in my car
All polo mk2 and 2f bases have the same jacking points so could search the breaking section and see if someone is willing to cut the parts out of their shell
