Buyers Guides…
Hi guys
New to this forum but not new to vw's
I'm looking to buy a cheap car for the GF…
Already having many vw tools and numerous vw's in my ownership history.
I have got the OK from her to look for a Polo.…
My budget dictates a 6n or 6n2…
Any pointers…
What to look for?
Potential problem areas? Quick fixes? Common faults?
Any and all advice gratefully received
BBB
  • Views 650
Depending what engine you go for depends what problems they have.
Both suffer from pedal boxes braking
Coil pack
HT leads
Distributor
Coolant temp sensor
Thermostat + housing
Gearbox bearings
6ns rust like fuck sometimes, 6n2's have galvanised paint so helps stop this from happening
Electric window mechanisms & switches
rust. (6n)
gear box issues effect both models.
pedal box braking.
rear wheel bearings. (6n)
poor spot welds on the hand brake bracket.
coil pack.
fuel pump relay. (vw supply a upgraded relay)
movement in the front seats. (caused by the plastic runner/bearing being worn/missing)
the front seats won't slide forwards and backwards. (caused by dirt/lack of grease)
my 6n2 has had the following wrong with it from the last owner and me alone.
gearbox rebuild
coilpack & leads
pedal box
central locking
electric windows
stat/housing/sensor
fan relay
rear washer jet leaking in the boot and ruining the locking mechanism (easy fix though)
