9N Rub Strips
Gonna be colour coding my rub strips soon and was wanting to know if the sport/gttdi 9N rub strips are smooth rather than textured? Would save loads of work smoothing them and all that :)
Batesy
  • Views 1.2k
I woildnt bother trying to take them off mate, you will have a massive bollock ache trying to fit them back on.
Unless your buying new ( which are uber pricey from Vw), then just paint them on the car.
Mask up around them right into the grooves. Then key them down with 320 grit, decrease them and a coat of plastic primer. Then use a good quality primer or filler primer. Use two or three coats until the bumps go away then use 400 grit wet and smooth them off then a few coats of paint and lacquer. Then leave them for a day or two before cutting or polishing, you can do them the same day, but as you will be doing them on the street or garage etc they won't be the best thing, so it's best to let it go off properly.
How are they held on mate?
Fronts and rears are on clips, sides are adhesive, but have locating holes on the panels/doors
Cheers for the info :) definitely coming off to be painted
Batesy
Batesy
No worries, I've done mine but as dixy said its a lot easier to leave them on and spray them which is what I did. Its fine doing that as long as you mask well :)
Yeah true, but youll end up with a top edge of the rub strip thats not keyed properly and chances are itll flake off knowing my luck
