1.4 16v 6n drivers hub
Need drivers side 16v 6n hub doesn't matter what the condition of the bearing and abs spigot as I have these basically just need a good condition hub carrier ready for sand blasting and fitting bearings and abs sensor must be 16v as 8v has different brake carrier mounting thank you
Also after a decay pipe for fitting on to a 4 branch for the afh
Edited by mikeobrien_88
  • Views 212
Popular Days
Want a pair? Pretty sure the 6n2 ones are the same..
