6n2 trim.
I want to remove the black trim on my 6n2 and replace it with silver (to match the body colour). The same with the door handles. Is this a pain to do?
Edited by John Cohen
  • Views 2k
  • nige8021
    nige8021
    The door handles are held in with a single torx screw (A) above the three screws that hold the door lock to the door Doors front Removing and installing door handle Removing ‒ Fit key in
If you take the bumpers off, you can unclip the bumpstrips and then spray them!
Unsure about the door handles, but I would presume they will be held on behind the door card
Doors front
Removing
‒ Fit key in door handle lock cylinder.
‒ Remove torx screw -A-.
‒ Push door handle forwards, turn key through 45°to right and swing door handle out of door.
Fitting instructions:
paddle on the lock must be in vertical position before inserting door handle.
Installing
‒ Pivot in door handle (turn door key 45° to right when doing this) so that the door handle slides past the door panel without an air gap .
‒ Screw in Torx screw -A-.
Tightening torque: 8 Nm.
Left-hand lock - right-hand thread
Right-hand lock - left-hand thread
‒ → Loosen tolerance screw -B- on door lock.
‒ Press in door handle.
‒ Tighten tolerance screw (Torx T 20)
Tightening torque = 3 Nm.
Do not move tolerance screw sideways when tightening (e.g. by supporting the key on edge of hole). The door handle must be pushed onto door outer panel.
Tightening the tolerance screw also takes care of the adjustment.
Perform functional check afterwards.
It is easy enough to get the strips off. I used fishing line just to make it easier. But it does take a lot of cleaning up to get the adhesive off and there are holes in the doors for pins where the strips are held on. Found out when i went to take mine off!
Post some pics if you do it, still considering the options myself :)
