removing mk2f ignition barrel
Need to change one on a mates car, any ideas how its done? Does it need drilling like the mk2 golf?
  • Views 1.4k
Popular Days
Removing and installing lock cylinder
Note Steering lock housing which has been drilled must not be installed again
Removing:
– Remove steering lock housing
– Mark drilling hole on steering lock housing. mk2fsteeringlock_zps0a4f59c7.png
a - 12 mm
b - 10 mm
– Drill into steering lock housing (approx. 3 mm), until the lock cylinder spring is evident.
– Using opposite end of drill compress lock spring and pull out lock cylinder.
Installing:
Note Steering lock housing which has been drilled must not be installed again.
– Push lock cylinder into new steering lock housing.
– By slightly turning key in lock cylinder it can be pushed in onto stop.
– Install steering lock housing
