244° schrick fast road cams
As title says. Bought to fit on a 100bhp 1.4 16v lupo sport but never fitted.
Price: £240
Contact: Call me on 07903203303, ask for Matt.
Picture:
Thanks.
  • Replies 13
  • Views 682
Hi will these fit the polo afh head and do you have any pics of the part number markings etc take it these are stage 1 ish so no need for ecu remap cheers
I'm not sure tbh. 350-001 is the part number. Can get pics later
AUB or AFH?
I would say AUB as they don't look like AFH cams
Is there a hole in the end of the inlet cam for the dizzy drive?
If not they're gonne be AUB?
Hi, these are mine
Part numbers are
350 E1 44100
350 A1 44100
Edited by Redfern!
There isn't an extra bit on both AFH cams for the dizzy drive tho
Only one has the extra casting to be drilled
Whereas on the cams pictured both have the extra saying bit
I have both sets of standard cams at home so il have a look tonight to double check for you
If they're for a Lupo sport it's AUB / AFK. I've looked into this before & been told they should fit both.
They're for the roller-rocker 16v small block engines, so won't fit AFH.
Check the part number in the Schrick Catalogue.
have you still got these
are these any good for the 1.6 gti engine. i would say they would fit but whats the score with the gti engine having a variable intake camshaft?
No good for GTi unless you convert to a static head, ecu etc.
These are for 6n2/9n/Lupo/Golf/Bora/Leon/A2 1.4 16v engines. They would also fit some 1.6 versions.
They would fit my engine, but attempts to convince the Mrs they're a priority has so far failed..
Also Fabias!
