vr6 polo mk2
jealous isnt the word
  • Replies 21
  • Views 2k
There's quite a few in Germany
It's easier for them being left hand drive with the servo on the other side
Easier on LHD's but not impossible to do on a RHD.
That's photoshoped... Look at it!!!!!! -.-
Around air filter and around left hand side of the engine, got a black outline.
That and the gearbox must be about half the length of the original 085 for the engine to sit that centrally.
Oh no, it's like on QI where they say the obvious answer. Cue tirade of those saying it's not impossible :?
Still, good shout on the photoshop.
Its not impossible Si
Sometimes it feels necessary to point out the obvious when surrounded by some many people constantly asking obvious questions. It becomes all too easy to forget that some people do actually possess at least a bit of common sense :lol:
Looks about as straight as Max.
And why do people complain about servos being an issue? Erm floor mounted pedal box? Issue resolved
I plan to do an engine conversion in mine next year which will, finally, do away with the short block lump and 085.
I will have to position my brake master cylinder elsewhere, and the solution is simple, doesn't concern me in the slightest. I shall be retaining the MK2 pedals and pedal box just as it is, and the MC will still be on the offside.
I wasn't complaining about the servo being an issue lol just stating the fact they have it easier
tbh I could easily do one of them conversions its no where near impossible especially if a turbo R36 (or R32) lump can fit in a mk1 polo bay
I'm running a bias pedal box in mine so I know that's the easiest way around that issue
theres obviously a lot more issues too but they have all been overcome
Mikey why would you want to do away with the shortblock lump, I can see the reason for getting rid of the 085 gbox but why the shortblock too
I have a shortblock mated to an 02M in mine and that would easily fit in a standard engine bay and the plus side is you get 6 gears if you want
Edited by StinkyPete
I found an engine I prefer, it's worth going for. Its not a choice based on the gearbox alone, I want the engine too.
Yeah a BCB would be alright, I was gonna do that before, but what I have in mind is a bit more special.
Yeah I know. I'm not sure my comment came over as expected. Damn attempt at poor humour :-/
If your thinking of the mk1 polo I think your thinking of it hasn't got a mk1 polo engine bay tho
Golf with mk3 front end and mk2 rear end lol
Has it not Guy tbh I've only seen the pictures that people took at gti fest last last October as I didn't make it
But there are a few vr6 mk3s in Germany same as g60's and 1.8t
If they can do it we definitely can
Empty bay, cut things til engine fits, make mounts, replenish lost strength, mount everything around it..done
Sure the scale of that's pretty wrong also, seeing a VR sits under the slam panel on a 6n lol. An AFH looks to take as much room as that in a mk2 bay
Mk2 has no servo anyway
A lot of the German ones have fitted servos to the mk2s
Just carry an anchor, remove brakes, less unsprung mass.
If you're doing that, fuck putting a VR in the bay, use that as the anchor!
Would give the same kind of power gains :lol:
