Best adhesive to hold Bump strips on
Hi all,
I've be thinking of refitting bump strip back on my polo but I'm not shore on what adhesive to use. I need something that won't leave a horrible mess if I decide to remove them again, so tiger seal is out of the picture. Is there any decent double sided tapes about?
Any suggestions would help greatly
  • Replies 10
  • Views 1.4k
Be desisive and not impulsive
Final Systems stuff is better than tiger seal
Edited by etches69
Just put one of mine back on with double sided tape. Turned out it was already stuck on with double sided tape.
Only reason it came off was because some massive dick head crashed into the side of me.
Curious as to the 'mess' tiger seal leaves, just tiger seal splatter?
It's just a ball ache to remove the residue left behind if i was to remove them again
Bad times.
Yeh they're held on with some sort of tape from the factory but i'm havin trobble deciding what sort to use. I don't what them to fall of every time i wash it.
I see what you mean.
My main reason is to try and stop all the dents that keep appering in my doors when ever i park it anywhere
Mine are held on by tiger seal, they're coming off this Friday, hoping not to remove any paint & bought a caramel/fudge/toffee wheel to help. Will reply back with how shitty it is to get off.
3m black double sided tape - prep the surface for whatever you use but they wont come off with washing and its easy and neat.
Tiger seal was fine to come off with the Fudge wheel. Now I've pulled the bump strips off, the tiger seal didnt hold them on that well tbh.
I've also only removed one side of the bump strips, but thinking about putting them back on because the rust stands out alot more :/
Edited by Craig_Fell
a good vhb tape would do the trick :)
