1 wheel drive MK2F
Driving the coupe the other day loud clunk under a sharp corner now its only one wheel drive :( sounds like its grinding as it drives and knocks as it sets off
  • Replies 12
  • Views 1k
check you cv joint and driveshaft
Having no mechanical real knowlage what am I looking for exactly?
Long thing that connects the engine / gearbox to the centre of the wheel
Has a rubber bit each end
Google polo driveshaft
As stated what am I checking for, not what am I checking :p
You said looking for but okay
Check its in one peice, check cv joints at the ends matey
Having re-read, I apologise.... *facepalm* what am I looking for what will broken cv joint look like
haha, a broken cv would be obvious, if you take a look online at pictures you should be able to tell the difference.
Jack it up out of gear and try to turn the wheels, if its a broken cj joint then you won't be able to turn the inner cv joint (near the gearbox) by turning at the wheel end.
If you hear any grinding etc when turning the wheel then determine where its coming from, hopefully not your diff, which will mean new gearbox time
Jacked it up and wheel came off, arb and bottom arm, well the bush inside the bototm arm was out so assuming its all just "popped out of place"
Well that sounds nice and dangerous, wasn't there a thread that alot of people had this happen to them?!
At least it didn't cause you to crash and harm yourself/others
