Kenwood DDX3028 Double Din
Hi,
For sale I have a Kenwood DDX3028 Double Din CD/DVD Player. I bought this around 18 months ago for £270 (Discounted price at an open day at car audio security) to go in my Polo, it was fitted for around 2 weeks then I took it out and boxed it up. It has been sat on top of my wardrobe ever since!
Spec (Taken from the Kenwood website):
Kenwood DDX-3028 6.1" 50W x 4 Double Din Car DVD Screen, with USB and iPod iPhone Control.
The Kenwood DDX3028 offers unparalleled iPod control. Plug your player into the receiver via USB, then use the 6.1" screen to take control. You'll see song and artist info displayed in large characters so you can see what's currently playing or find the perfect song.
Once your iPod's connected, you can view album art, plus control and play video from your iPod in your car. You can watch your favorite DVDs or iPod video on the built-in screen whenever you're parked.
You can use the touchscreen to change sources, choose music, select DVD menu items, or adjust EQ settings with just a few quick touches of your fingertip. You can also set the Kenwood DDX3028's control buttons to match the colour of your vehicle's dash illumination.
The Kenwood DDX3028 plays all your CDs and recordable discs loaded with MP3, WMA, and AAC files. Or you can plug a USB flash drive full of music into the receiver's USB input for hours of listening enjoyment. You can plug gaming consoles and other audio/video sources right into the handy front-panel A/V input.
Kenwood DDX-3028 Main Features
6.1 inch Touch Panel Control with Full Graphic User Interface
DVD Video/-VR/±R/RW, DivX, MPEG 1/2 Video File (.mpg) & JPEG File (.jpg), AAC, WMA, MP3 playback
1 USB input (front panel)
iPod direct control
Works with iPhone
Variable key illumination (Hard keys & GUI colour)
1 AV-In(mini-jack, Frontpanel), 1 AV-Out (RCA)
1 RCA Video Input for optional Rear View Camera
Navigation with optional KNA-G620T
Bluetooth Handsfree / Audio streaming with optional KCA-BT300
Kenwood DDX-3028 Monitor Features
In-Dash Double DIN
LCD Type TFT 6,1" Wide
Screen Adjustments Brightness/Tint/Color/Contrast/Black Level/Dimmer
Auto Dimmer
Visual Source Mode DVD/Video/Navigation/(TV)/USB/iPod
Touch Panel
NTSC/PAL: Auto
Full Graphic GUI
Background Customize
Kenwood DDX-3028 Tuner Features
RDS (PI, PS, AF, TI, Clock)
Radio Text Plus
Program Type Function (PTY)
Enhanced Other Networks Function (EON)
K3I - Clean Reception Tuner
FM Reception
AM (MW/LW) Reception
Presets 24 Presets (18FM / 3LW / 3MW)
Station Select List
Automatic Memory Entry (AME)
Up/Down Seek Tuning
Tuning mode (Auto1 / Auto2 / Manual)
FM Stereo / Mono Selector
Kenwood DDX-3028 DVD-Features
DVD±R/RW Compatible
DVD Region Code 2
VCD Compatible
CD-R/RW Compatible
CD Text
MP3 File Playback
ID3 Tag Display
WMA File Playback
WMA Tag Display
AAC File Playback
AAC Tag Display
Digital/Analog Converter 24 bit
Shock Proof
MPEG1/2 Video File (.mpg) Compatible
JPEG File (.jpg) Compatible
DivX (Certified)
CD-DA Repeat/Scan/Random play
Direct Search
Time Code Display
Resume Play
Zoom Control (DVD/VCD)
Disc Menu Direct Touch
Picture Control (JPEG)
USB Features
USB Interface port : front
USB Type USB1.1 / USB 2.0
MP3 playback with ID3 Tag Display
WMA (Windows Media File) playback
AAC (Advanced Audio Codec) playback
WAV (Waveform Audio Format) playback
MPEG1 Video decoder
MPEG2 Video Decoder
DivX Video Decoder
iPod Features
USB Audo Direct control (2 wire) : with optional KCA-iP100/101 cable
USB Video & Audio direct control (3 wire) : with optional cable KCA-IP22F
Music playback
Video playback
Alphabet search
Skip search
Control by hand : only for iPod nano 2G/3G/4G/5G, iPod Classic, iPod Touch & iPhone
Works with iPhone
Battery charge
Audio features
Max. Output Power (MOSFET Power IC) 4 x 50W
2 Pre-out RCA: Front/Rear
Pre-out Output Level 2V
Auxiliary Input AV Front Input
Rear / Subwoofer Switchable
Subwoofer Reference Level Adj.
Dual Zone Source & Volume Control
Dual Zone (FRONT / REAR Switchable)
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader Control
Loudness Control
Att.(-20dB) with smooth Volume Return
System QEX (Preset & Manual Sound Control)
System E's+ (Built-in HPF & LPF)
Beep On/Off
Video Features
Audio/Video Output: 1 RCA
Audio/Video Input: 1 mini-jack in front panel
Video-In for Rear-view Camera: 1 dedicated video input (RCA)
Mirror-mode on Rear-view Image
Detection Mode Rear View Camera Reverse sensor wire
DVD Menu Direct Touch Operation
MPEG Decoder
TV ready (optional TV Tuner required)
Connectivity
External Media Control BUS (KAB)
Bluetooth Control (KAB-Bus)
iPod Direct Control (2 wire) - requires standard iPod cable or KCA-IP100/101
iPod Video Direct Control (3 Wire) : with optional KCA-IP22F
OEM Wired Remote Control (requires additional adaptors)
Parking sensor wire
Reverse sensor wire
Power Control (P.CON) wire
2-way (Tel/Navi) mute wire
Dimmer control wire
TV Tuner Control
Navigation RGB Input
General Features
DIN Size 2 DIN
Disabled System Indicator (DSI)
Security Code Function (Fixed)
On Screen Display (OSD) Operation
Smooth GUI
Selectable GUI Background Wallpaper
Key Illumination Variable colour
Installer Memory
Back-up Memory
Attenuator with Smooth Volume Return
Touch Sensor Tone
IR Remote Sensor (remote optional)
Digital Clock (24H)
ISO connector
Pics (Sorry crap Iphone):
These RRP from Kenwood at £299.99
Price - £200 FIRM
Location - High Wycombe
Contact - 07506 four four three 445
Harry
Edited by haz911
  • Replies 14
  • Views 979
£150 takes it!
its ok got one now
Edited by nuttyscoot
Does it have gps?
  • 5 weeks later...
Does it have gps?
Yes it has GPS capability built in but will need the disc/configuration.
Want this gone now....OFFERS FOR A BRAND NEW HEAD UNIT
Any chance you got any pics of it fitted and working?
Nope sorry was only in the car couple of weeks max......
Don't really buy electrical gear with out it been seen working :/ what's the lowest your take?
More than welcome to come test fit and see it working? £150 ONO....I paid almost £300 and it was in my car less than 2 weeks.
Ok will have to do that, where abouts are you ? just the other side of west london ? has it got the cage to go with it ?
do you still have??
do you still have??
Yeah still got it...
£150 ONO
SOLD!!
