MK2 Front Seat Options
Hi All,
Whats the collect view on replacement seats in a mk2 Breadvan ? mine have had it now -
I'd like somthing that is either a direct swop (Corrado's fit as a stright swop ? ) or something simple to modify.
let me know guys.
D.
  • Views 1.2k
Hi All,
let me know guys.
D.
corrados fit but be warned they are very low compared to the standard polo ones, if your very small you might need a cushion or two :-)
mk3 polo, Corrado, mk2 scirocco and mk2 golf front seats will fit the later mk2s directly, some modification is required to fit them to very early mk2s (the lever to adjust the position of the seat switched sides in the early 80s)
Scirocco seats are like armchairs, a bit wide for the polo really (clearance for the handbrake is bad if you dont have the seats all the way back) but they do go in and with a genesis rear seat bench you have a nice matched set.
As above on the corrado seats they are by far and away the best seats if you're tall. They add a lot of knee room but they will pretty much eliminate rear leg room if you have them set right back.
What are the mk3 Golf GTi seats like. Woll they be a straight fit into my '85? And rear bench too
Mk3 golf don't fit
will do if you bend the subframe abit .. :)
Could I just not put the polo seat subframes on? I'm sure Eric had Golfs in his.
