changed wings on polo 9n need help
so I've managed to change the nearside wing on my polo after a little frustration however i cant seem to get the bumper clips back on. There are 3 clips?and 3 posts needed to get it back together however no matter how much i try i cant get the bumper flush with the wing. Has anyone else had this problem and if so i would be very grateful for some advice .
Thanks in advance
Mikel99m
  • Views 995
Thanks in advance
Mikel99m
Heyup are they genuine VW wings or spurious panels??Usually there arent any probs with genuine panels but most of the time with none genuine panels a little bit of fettling is required which can be very frustrating :? Another solution is keep everything loose and make it all line up with your hands and then tighten everything up slowly nut by nut and see where the panels move too before you put a final pinch on everything.Good luck hope this helps.
