Tried and tested ideas.
standard 6n2 1.0, my first car had it almost a year and insurance is going to be dirt cheap next year so keeping it.
Obviously a little bored with it. I'm fully trained in mechanics and I've not really mess about with it yet!! But as my first car and only being a bargain £800 don't fancy spending another £800 on the usual coilovers, banded steels....so on.
I've played with the air box, de restricted it and made more of a cold air feed its given a nice throaty sound. Wanting abit more noise now so looking at the exhaust, I don't want it stupid like some 17 year olds 106 so looking at the centre pipe silencer. Now this is where the title comes in... Has someone just removed the centre pipe silencer? Obviously it will make a different in noise but is it worth it or would I be better off with a back box instead?
Now another one.. I've painted the original wheel trims black, pretty proud of this everyone asks if they're alloys! But obviously the standard ride height is some what, off road like. now coilovers are out the question! But I've noticed the polo GTI sits a lot better as standered so I'm looking for some GTI shocks for my car maybe with some lowering springs. Again as in the title has anyone done this and been happy with the new ride height?
I'm not expecting many answers to be honest but if you don't ask.. It's really to try save some money and time as i will probably do this if no one else has tried. Also if you have a cheap or free way of improving my car id love to know
Edited by Cymro
Unclear title
  • Replies 21
  • Views 1.3k
Just run a straight through from the manifold... full on BAAAARRRPPP!!
Put 32psi in your tyres.
Why are coilovers out of the question? You'll pick some up for under £100 off here.
Black wheel trims and wanting to make it louder... it's sounding like a 17 year olds 106 at the moment.
Edit: But a 106 is prolly quicker.
Edited by Jaake
Insurance going dirt cheap
HAHAHAHAHA funniest thing I've read all day.
On a serious note, if its money saving then leaving the modifications alone is the best bet. Any changes to the vehicle would need to be declared and that would push your your insurance up even further.
In the event of a crash insurers will look at any method of getting out of it. This includes fiddling with your airbox.
TBH all adding a loud exhaust will do is make a lot of noise with no go same as most of those 106's.
These replies seem to be a bit negative. Not once did I say i wanted to make a 1 litre polo faster I'm just after improving the over all look from standard. The wheel trims where painted black because they where scuffed and black would hide the very large profile of the tyres. I modified the airbox purely for the sound and I'm wanting to do the exhaust to hide the poor engine/road noise and obviously who doesn't want a sportier sound but thank you for your less then helpful input.
I had a straight through exhaust on my 1 litre corsa and it sounded awesome but looked a idiot as I wasn't moving anywhere fast. Remove the centre silencer will make it sound raspper and you may get a few pops but you may aswell remove cat aswell and it will be louder. As for improve the look there's a set of coil overson here now for 120.
If you want to lower it a little I'd just stick some 40mm lowering springs on your standard shocks, takes some of the gap out and isn't too low. Will put more stress on your shocks and deteriate then quicker but at 40mm it shouldn't do this that quick
Cheers about time for some decent replies!
Corsa's don't come with a centre silencer do they? I know having a straight through pipe sounds good but like you said I don't want to sound like I'm going fast and only going 10mph. Trying to keep it quiet untill you put your foot down
Yeah that's basically what I'm looking for, but knew it would stress the shocks that's why I was thinking GTI shocks would be better i think they're lower?
I was just thinking of saving you money, yeah go for the gti's as they're 30mm lower I think (not 100% sure though) could probably withstand 50-60mm sprigs before becoming too stressed
Anything over 30mm will stress the shocks quicker. Even gti shocks I'm guessing the springs are different from standard springs as well so its the same as putting 40mm on stock shock. It's just the gti may be uprated slightly to deal with the harder springs. Correct me if I'm wrong. I personally would buy coilovers so you can set them to what you want.
And yes corsa's do come with centre silencer and removing this made the smallest change in sound
My reply wasn't about performance, it's also a 'tried and tested idea' to improve your car's economy and agility. Your own "less than helpful" input was a failure to explain what you wanted to such a degree that a mod had to help you do so, plus sweeping the above replies into the same coverage ("These replies") only adds to show yourself as having an unnecessary - and ironically also a negative - attitude.
Good luck with your search for help, dude..
Cheap ways of improving the 6n2 (look on galleries)
If you just want the sound from the exhaust, have a look at cherrybombs
Painting VW front logo black or whatever (mines orange on inside as in dp)
Painting rear VW logo
De-Wiper
GTI grills (little expensive, £45 ish for full set + fogs)
Different interior (can be had for £50)
Cheap alloys (£80+)
Stubby Aerial (£10 ish)
Leather gear gaiter (£6)
Audi TT Pedals (£45+)
New VW centre Caps (£5)
Club Polo Sticker (£5 membership)
New Stereo (£30+)
Tinted Windows (£100 Professionally)
Paint calipers (pointless with steel wheels)
Dust Caps
Good Old Clean!
Car Mats
Theres some ideas. Nothing is free
i've got a 1.0l 6n2 and I'm running standard back box (with a little mod :ninja:) with no center silencer and I'm quite pleased with how it sounds. It's only slightly louder but sounds alot better, and with my induction/filter set up which is the standard cover/air box with filters removed inside, some of the plastic cut/shaped for smoother air flow, exhaust hot air feed blocked off, then a K&n style cone filter fitted to the outlet of the air box with a cold feed running into it aswell. Together it defiantly lets the engine run better and improved throttle response. If you change gear and punch the throttle back down you can really here the induction noise which is quite cool!
Now about the suspension.. I do have some ap coilovers waiting to go on and tbh I've seen alot of second hand coilover sets in fair condition for sale from £80-£140, but you can get brand new sets like fk or joms for around £200. But anyway I'm currently running some fk springs which are supposed to be 75mm on the front and 65mm drop on the back. I used these on my standard shocks but the ride was pretty bouncy ad defiantly not a 65-75mm drop so after a bit of messing about i decided to cut the front bump stops to half the size as the car when on the floor was decking out on them, but now it has a bit of travel and rides very well. I also cut the backs in half so i have more travel then chopped the a coil off the rear springs so it sat level. Now my car sits pretty decent considering its on springs and rides really well.
Hope this helps!
p.s I'm in a hurry so i cant be pissed to mess around inserting images but heres a link to some photos...arch gap is smaller in person and its settled now!
photo 1
photo 2
Surely that would let rain and stuff in and not let it out?
Cheers for all the replies! Helps a lot.
Thats some cheap lows right there :thumbsup:
Edited by Tramp
Am I missing the joke here?
AHAHAAAAA
Drill a 2mm at the bottom of the pipe
Cutting the springs for cheap (but dangerous) lows
take the center box out gave my 6n a nice rasp between 4 and 5k! and get the angle grinder on them springs 2 coils should do, :) might make it a bit stiff tho (I'm talking about the car), Happy modding
