Polo Gti oil consumption
Hey, was just wondering what are other peoples oil consumption for the current Polo Gti? I've personally had to use 3 litres plus what ever the car comes with over roughly 4600 miles?
Thanks in advance!
  • Views 1.6k
Take it to a dealer it's a known problem.
There's a modification for breather pipes and at worst a new engine.
Just make sure you've got no mods on the car as they will make an excuse not to do the fix or try to invalidate your warranty.
VW currently don't seem to want to acknowledge that there is an issue with loads of these engines and make you go through an oil consumption test. I.E. They top it up and make you come back when the oil light comes on about 5 times.
Apparently there is also different piston rings that they can fit.
If it's still under warranty make sure you've got no mods and don't let your dealer fob you off with any bullshit, cause they will try it.
There are loads of people with this issue and VW are being pretty crappy about it. Tell them you know it's a known issue that there is a fix for and make them do it.
!m!
OK thanks guys. My brothers friend works at Volkswagen and he said that's normal, apparently the technology in the performance engines to help get better fuel economy results in a higher oil consumption.
Will take it to Volkswagen and see what they say as its only 6 months old.
