G60 brake conversion
What Brakes Should I Fit? 9 members have voted
  1. 1. What front brakes do i fit to my GTI 6n2?
    • G60 brake conversion standard discs/pads
      55%
      5
    • 6n2 drilled/grooved disc with green stuff pads
      0%
      0
    • G60 brake conversion with drilled/grooved discs and green stuff
      33%
      3
    • 6n2 standard discs/pads
      11%
      1
Please sign in or register to vote in this poll.
If i was to do the G60 brake conversion what parts would i need for it to all fit? Just calipers and carriers?
  • Views 2.3k
IIRC, all you need is the carriers from a corrado VR6 and you can use your calipers... but my thought on that was that you're going to have a gap of like 24mm on the disc?
So to do the conversion i will need calipers(if i want them) and carriers. I won't need the hubs aswell? also will corrado disc's fit straight on to get rid of the gap or will i need to keep standard polo disc's on?
How can you go to 280mm brakes with standard 256mm Polo brakes?
With the Polo GTi - as it's 256mm brakes and the caliper and carrier are separate units, you can swap the carriers and keep the carriers.
This means you can keep the hubs.
All you need is carriers and discs.
I wasn't sure if the hubs would be different with bigger carrier/disc's. Are the G60 caliper and polo Gti caliper the same size? what size are the pistons? or is it you can use either caliper and fit G60 brake pads that take up that little bit extra disc surface space?
I have found out that the G60 disc's are 2mm wider, so that means i will need to modify the sliders by cutting them down so the pads don't foul the disc's
I was just looking at the brake sizes for the VR6 and they are 288mm compared to the G60 brakes that are 280mm will the VR6 brakes fit still??
