NEED ADVICE/HELP
Does anyone highly recommend the vw polo 9n (2001-2005) 1.4 tdi pd engine 3 pot 6v 75 bhp ?
First of all i wanted the 1.9 sdi but i got told it was a no go as it was really sluggish and would regret it. So everyone who iv'e talked to so far recommends the 1.4 turbo diesel. any advice would be great. thanks.
  • Replies 19
  • Views 1.8k
please help as I'm thinking of buying a car soon. apparently there is a 1.4 4 cylinder engine too.
I have have mine for 3 months now. I think it's my best buy so far. It pulls when you need it to, I'm getting 55+ MPG
All round great car IMO
which one do you have? engine, year how many cylinders etc? thanks for the reply matt.
I have a 2001 (Y reg) 1.4tdi PD 75 BHP (they are all PD) 3 cylinder 6valve AMF engine code.
I would definitely recommend it, just make sure there is no turbo noises and the clutch + clutch pedal feels good. Poor quality of servicing and wrong oil can strain the turbo
Edited by matt01
is that the 6n or the 9n ? turbo noises as in ? how should the clutch feel, low biting point ? i heard using the wrong oil for turbo engines is bad so I'm just gonna do an oil change with the correct oil as soon as i get it.
Mines a 6n2. They never did a 1.4tdi 6n.
Noise would be like a tinny/rattle when you put your foot down and the turbo kicks in.
Low biting point is good, half way up is still ok but if our getting to the top of the pedal before it bites that may indicate a problem. Listen for clicking noises when pressing/releasing the clutch pedal (you can do this parked up at idle) if it clicks it may indicate the pedal box being faulty or another issue
so basically the turbo starts to shake itself to bit because its either been abused to bits or its just severely worn. they make this noise because the big bearing in the centre with the fan blades on goes. the way i test a clutch to see if its good is obviously the biting point but i stick it in 4th or 5th gear and let the clutch out, if the car stalls then its good but if not then the engine isnt getting drive from the clutch. that can be quite hard on the engine though.
Yeah man just check it out :thumbsup:
thanks for the input mate. been really helpful.
I have had a 6n2 1.4 tdi - cracking engine, bit noisy but great fun. The 9n are the same engine as far as i am aware. Be careful with gearboxes. The 9n do a 1.9 100bhp tdi which is a good engine.
i would get a 1.9 tdi but they cripple me on insurance and they are more tax, less mpg, turbos go on them alot more etc.
i think I'm gonna get a 2002-2003 9n 1.4tdi and look after it as my last 3 cars have cost me stupid money to repair just wear and tear never mind modifications.
I had that on my jetta td when I first fitted the engine, decided it should go out in style and whacked the boost up to over 30psi. Surprisingly the noise disappeared and the turbo lasted for two engines and about 2.5 years until I sold it :lol:
Jeez that's good!
I've got the noise on mine so hopefully it'll last as long :lol:
they didnt do a 4 cylinder 1.4 TDI, in 6n2s or 9ns. the 4 pots are for the 100bhp+ models!
and dont be put off by high miles, mines on 182k and its still going strong.. they last forever if you maintain them properly.
belts are recommended to be changed every 60k and the water pump every other belt change so enquire about that and if its due one (or hasnt had one done before), you're talking a few hundred quid to get it replaced.
as previously said really, check for any dodgey smoke (a bit of black smoke is natural for a diesel) and rattles when you give it a bit of throttle. I've heard its an engine out job to change the turbo, and judging by the location of it, i'm not surprised! :lol:
Just a bit of advice as everyone is saying about the turbos going in these cars, when you buy any turbo car you need to look after it. The main problem with them going is because people turn the ignition straight off once they have stopped the car. What you need to do is at the end of EVERY journey is let it idle for at least 60 seconds so the turbo can slow down whilst still getting oil feed, the problem is as soon as you turn the engine off it stops feeding oil to the turbo, and so the turbo 'fan' is then running at a high speed with no oil, and we all know what happens to bearings with no oil on! :) just a bit of advice for you all
Yeah already knew that, always leave mine to idle for 30 seconds or so. Wouldn't say over a minute but suppose everyone hears/learns different ways :thumbsup:
Someone was probably trying to bullshit me then. Yeah I know not to be bothered about the mileage with a diesel as long as it been looked after and no turbo noise. That's why I'm looking for 1 old lady owner car lol. The engine out just to change the turbo ???? That takes the mick lol. My mechanic where I take it does timing belts quite cheap.
I thought this only applied when you have just pulled up from a spirited drive :ninja:
Mart would you still recommend even if I'm only doing 3k a yr which is like 6 mile a day. It's just I heard that diesels can start getting expensive if they are not run for a good few miles as the don't get time to warm up.
