Wet boot! how do i find the leak
I noticed my boot was wet when i took some bags out. i checked the back seat and that was damp. i wondered if rain was blowing in the windows as the weather has been so bad. i checked the windows and they were shut tight.
i took the boot up and the spare was sat in about 4 inches of water so i definitely have a leak. i have looked at the boot seal but it doesn't seem to have gaps or be perished.
any ideas please
  • Views 1.4k
Get some one to sit inside and get the hose pipe on the car and get them to spot leaks. You may need to remove trike to actually find the source. What car is it?
Check the rear lights that's where mine was
Do you park your car on a hill facing side ways (if that makes sense) or on the flat? because if you park on a hill side ways, i've had a few different Volkswagen's including a polo leak through the air vent in the boot. 1 is located on the o/s underneath the central locking pump tray and the other is on the n/s down behind the boot carpet near the light.
If that is where the leak is coming from you may have to remove the rear bumper to reseal it. I'd use a bathroom sealant. but don't block it off as they are what let the air out of the vehicle when a door gets closed (stops widows being popped out/smashed) like on old escorts lol :)
Fold the back seats down and take the boot carpet out.
Put it in a car wash, and climb in the back.
Watch for a water leak, and where it's coming from.
thanks for the suggestions
We've done the hosepipe method. it was pouring in through the rear light.
we've dried it out and it's sat on the drive with a De-humidifier and heater in it. There could be another leak but we've sealed the light housing and fingers crossed that might be it.
