Elsawin 4
First off I'm not sure if this is the right section so sorry if I should be posted elswhere.
A couple of months ago I purchased Elsawin from eBay as it was recommended to me by a few people on here, I managed to find a copy for just two pounds! So I got it and installed it with no trouble at all, and I have used it a few times. When I came to use it today I opened the program up and a message popped up saying this software is not licensed or something along those lines and now it won't work at all. I realise its obviously a copy but does anyone have any experience with this and know if there's a way to fix it without uninstalling it? Its no big problem as it was only 2 pound but it'd be good to get it working again.
Cheers in advance for any help you can offer
  • Views 1.4k
I've had mine running for a few years now without any warning messages like that? but I did pay about £15 maybe yours had some time limiting built into it?
That's what I'm thinking! I've messaged the seller but I doubt I'll get a reply. I might just end up paying more for something a bit better :) is etka worth getting?
If you can get a working copy of ETKA definately :thumbsup: Not had any luck so far :-(
Haha I'll have a look about :) there's some on dhgate but I'm not sure if they work or not. Other than elsawin and etka is there anything else I could get?
Vagcom 409.1 or the newer VCDS diagnostics
ETKA there are a couple of online versions available vagcat.com need to register but it's free or there is a Russian version http://vin-online.ru/etka.php?vag=VW but if you use google crome it will automatically translate it for you
Cheers for that, I'm saving up for the hex can interface at the moment :) hopefully I'll be able to sort elsawin out as it was pretty helpful!
