MK2f Side Bump strips Removal
Wondering if anyone can help me? I am looking at removing the bump strips from the sides of my coupe, my first question, are the strips only attached with adhesive? Secondly if so with the adhesive is it a pain in the ar$e to remove from the paintwork?
Thanks in advance.
  • Views 1.2k
Thanks in advance.
Just adhesive use a heat gun and a fair bit of heat, otherwise itll rip the paint off with it
hmm i disagree, the paintwork will not be pretty bare in mind it has been covered up for 20 years or so. you can just pull the mounts off and it will leave the foam tape on and you can remove that with a fudge wheel.
So really your doors will need painting either way. And remember they have a purpose your door will be dented to hell very quickly
Ok thanks for the advice, they will be staying on!
