Heads up for anyone fitting mk2f seats in an early mk2 coupe
Just thought I'd post this up here for anyone who is planning on fitting mk2f seats in an early mk2 coupe. I did some searching on here before deciding what seats to fit in my mk2 coupe and there was a lot of posts saying that the mk2f seats will fit straight in, technically they will fit in but the problem you will have is that the seat adjusters for the mk2f seats are the opposite side, so you will need to modify the seat runner adjuster on either the floor of the car or on the bottom of the seat, I decided to modify the one on the floor of the car as I didn't fancy trying to weld the bottom of the seats without setting them on fire :)
Here is what I did, if you look at the before picture the tube for the adjuster pin is on the l/h side, and it needed to be on the r/h side so I just welded another piece of tube the same length into the opposite side and drilled 2 new holes for the springs to clip into. Obviously it would have been better to spray them silver afterwards but charcoal spray was all I had to hand, plus you can't see them when the seats are in :)
  • Views 1.2k
i thought the mk2f seat bases were symetrical? dont you just unscrew the 4 screws which hold the aduster handle on- swap sides with the passenger/driver and then screw them on in the holes on the other side?
When I post in these 'do x seats fit in y' I always mention that early mk2s are different to later ones/mk3s. I have some corrado seats in my y reg and I simply swapped the lever over to the other side (the holes were already built into the seat bases) So yeah, as above I think! Only issue I had was the tilt adjust was slightly in the way so I removed the handle for it and now I only have the stub.
With the passenger seat it is possible to swop the seat adjuster handle over as it is screwed on but to get to the back screws you have to strip the bottom off the seat, but the drivers side seat adjuster lever assembly is actually welded on at the back and screwed on at the front so the only way to swop it over would be to chop it off and weld it back on the opposite side
Yeah to be fair Gaz I did see a post of yours over the weekend saying mk2f front seats do fit but require modification of the adjusters so fair play to you mate
