Carbed turbo conversion
Well the time has come to sell this on. i have not had it long but I have to let it go i was gunna put this in a mk2 and after bolting it all in and getting parts organised I realised I would need to cut the front brace out to allow room for oil cooler inter cooler and the down pipe. So with time not on my side and buying another car this has to go. The kit comes with
8v turbo manifold
T2/T25 hybrid turbo
turbo oil feed
refurbished renault 5 turbo carb and solex inlet manifold for a polo
random bits of 3 inch downpipe
vaccum advance canister for turbo setups
renault 5 turbo fuel pressure regulator
3 bar fuel pump
So all you need to finish this is a sump with oil return and intercooler and oil cooler and some boost pipes
I would advise not doing this on a mk2 I know the mk3 have more room in front of the engine so shouldn't have a problem. I'm sure it can be done in a mk2 if you have more time then I do.
Looking for £420 as I have bought the pump since buying of Eric for any pics of it in a mk 2 bay have a look at his build thread
Edited by mattieboi6n
  • Views 672
Quick question, what does the pressure regulator look like?
They look like this....
Bump
wouldnt you need to lower the compression to fit this? sounds like an awesome conversion but unless going on a g40 bottom end..
any pics?
Being as the the early 8v engines have a low compression ratio of around 8 - 1 so u can safely run 6-8 psi on a healthy engine and get around 140-150 bhp.
post-118433-1369684221_thumb.jpg the only one I have Eric has more on his build thread
Ttt
