Spline adaptor removal
Trying to fit my mk1 gti steering wheel to my polo gt but encounter a spline adaptor which seems to be on pretty tight.
Car is at my girlfriends and don't have many tools there so didn't try very hard,
Could I use a slide hammer to get it off?
Don't have a bearing puller set and can't be arsed buying one
  • Views 1.5k
If you can apply some heat then tap it with a hammer to free of but if you could make a fork attachment for the dlide hammer I'm sure that would work to
I did think about heat but no chance without melting my dash :thumbsdown:
Will try making a fork for the slide hammer tomorrow and see how it goes, have previously removed half shafts from an axle with a slide hammer so if it can do that it can surely remove a spline adator lol
Cheers mate, we have one of those in the workshop at college, can't afford to buy one at the moment though (gotta insure and mot the car)
Will give it a shot with the slide hammer and see what happens!
If you manage to remove it I'm after one. Been trying to get the one off my breaker but it's going nowhere! I've tried a couple of normal pullers but they spread apart too easily. I managed to get a ratchet strap to stop that happening but then I was bending the legs of the puller! (I'd modified it to remove gearbox 5th gears so the legs were a bit on the thin side)
That set will do the job for sure, I'd buy one but I don't think I'd need it again!
Best thing is to put a large adjustable spanner behind it, this lets you grip a bigger area with the bearing puller.
Well, the slide hammer didn't work, ended up nearly smashing the windscreen lol!
I'm considering making something to get it off, not got a lot of free cash at the minute because I'm trying to get two cars on the road before summer
Similar concept to the bearing puller though, should be pretty easy
Plus can't see me using it for anything else as Gaz says - I'll give you a shout if I get it off in one piece lol, I won't be needing it again
