Polishing New Paintwork
So the end is in sight for my repainted wagon, and I think I shall be done relatively soon (dont hold me to that mind!). Anyway I'm looking to get a super glossy finish on it (to hide any imperfections if nothing else) however I can only find guides on paint correction. I'm hoping I won't have any swirl marks and scratches when I'm done so most of these are no good for me. I plan to wait a month before i do this to let the paint fully harden, last think I want is it all peeling off after it's just gone on. So I'm wondering whether anyone can offer any more advice, such as pad/polish combos.
I'm thinking I'll go with some G10 first - but what pad?
Then some sort of polish - I have some maguires I use by hand, is this suitable?
Can I apply wax using a rotary polisher? Again i have some i use by hand can I use that?
What pads do I use throughout?
I know there are dangers of paint burning with a rotary, so I don't want comments saying not to bother. I will test technique out on my tried and tested test panel first.
  • Replies 9
  • Views 1.5k
I have used a rotary in the past, ands it not as bad as what everyone makes out. The only paint I went through was on the edge of a panel that had been sprayed by Stevie wonder.
As for pads and polish, get your self a brew and a spare few hours and have a look on detailing world.
X2 for detailing world.
I'd still clay it probably to remove any shit that's got caught up in the paint; then polish it how you like, use a sealant then a wax.
My selection that's doing me proud atm.....
Flat with 1500 wet, (can use 2000), using a hard block on the flat sections, dry regularly to check your progress, its easier to see where is done at this point.
Then 3m fast cut + with the matched 3m green pad,
Micro fibre the acces polish and swirls off ( dont have to go crazy at this point )
Have a good inspection at this stage, how it looks now is pretty much the finished article, any imprection seen will need a extra nib with the 1500/2000
Then I use a HB body finer polish with the 3m blue pad, the pad is made to match with a 3m polish (blue top) but this gives me good results,
Then wipe away again with a microfibre
Obviously make sure the pads are nice and clean, if you clean them under the tap, then dry them as much as possible or your gonna get messy!
As for worrying about cutting though the paint, just start on the flat panels till you feel your in control of the mop!
I done mine 3 days after I painted it tho, leaving it longer will make it harder work, but will still work, using the 'green' products should help!
Just remember I've got some pics! ......
You can see the blue pad on my mop in this one, get one with the egg box texture
Ignor the wheel..... Look at the paint, this is prob the best pic I've got of the finish
1A9D444D-0BE1-4C7F-8D06-5E4CDDE4A44C-212
Anybody else who does the same stuff I'm sure will have different methods, be interesting to read them...
Then for maintenance all I use is auto glym SRP and a wet web by hand, as when I'm feeling the love!
Edited by SuperMario
1500 wet and dry? Is this just for newly painted or can it be used for slight imperfections?
I was thinking of getting one but it looks to be £150 to get kitted out.
What supermario said...exactly what I would of suggested.
Just to add to his advice, for an even better finish. I'd say, do 1500 wet then use 2000 3m trizact wet and 3000 3m trizact wet. Means you have an even smoother surface to polish back meaning a nicer finish.
Chris there's some in jtf at the minute for 20 quid + VAT, Iv only seen them in news letter and it doesn't state if they have variable speed or not but if they have its winner winner chicken dinner. Well it won't be the best but for a one off (which in my case it seemed to be) it might be worth the punt.
yeah dude you can use it on 'old' paint, just means somebody didnt do it when they 1st painted it!
Also to add.... If you use a brand new green pad, I find there quite firm and need 'bedding in' just start on the bonnet !
Meguiars ultimate compound and ultimate polish have worked great for me with polishing and finishing pads on rotary, same car as yours but orginal paint
Also wouldn't apply wax via rotary much better suited to da or by hand
