BMW 320cd Msport
Hey people, me again :)
Just got myself a BMW 320d Coupe Msport, not really sure why, was looking at golfs and A3's, had an idea of getting one of these then bought one 4 days later, not much thought or research into it at all.
So picked this one up, it's a fairly straight example, perhaps a bit neglected in its life but I intend on making it nice & mechanically sound, and a few subtle mods.
So from what I have worked out there's a massive spec variance and no real consistency with BMWs due to everything being an option. But some basics:
Msport coupe, 2.0tdi, 150hp, silver grey.
18" MV2 alloys
Black leather seats
Black head lining
6 speed manual
Cruise control etc
109k
Really solid car, if not a bit bland because its pretty well refined, the suspension is pretty firm but not dramatic, engine pulls well, totally different to my golf diesel, that was dead pokey at low revs, whereas you need to wind this one up a bit, however I'm still getting used to the 6 speed box etc, starting to like it more and more now.
So I went and picked it up, drove it home with intentions of doing a few service bits. However, opened the bonnet when I got home to be greeted with water leaking - not cool! Hole in the rad it turned out to be, but was ok when I went to check it out, rang the guy up straight away, who's sent me back the money for the cost of the rad. Wasn't happy to be honest, stone or something perhaps, but these things happen.
So literally got home, found leak and took rad out...
3f781ab7c8087d1709a18629eecc0778_zpsa0ce
Flushed the system through, banged the new one in..
e247a01d33a1dee520ee44f1248acfdf_zps15f6
Got that done, then carried on with my actual intentions, which was removing the problematic swirl flaps. These engines basically have a variable length inlet tract, which is controlled via flaps. Which like to fall off and get sucked into your engine, ruining pistons/heads/valves, oh and turbo's on their way out.
So took the inlet manifold off and removed them and fitted some blanks, I had only drove it home so I wouldn't really notice the difference, although its supposed to be minimal.
Blanks fitted..
d2d3dd0d0adc2473f44add99841a57ea_zps57aa
Whilst it was in pieces, I decided to give it a service, even though its got FSH, I like to know where I'm at.
So replaced:
Oil filter
Air filter
Micro filter
Fuel filter
Oil (obviously)
And the oil seperator, as these can cause turbo issues.
All changed for genuine BMW parts, a small fortune it seems!
Ran a lot smoother after doing that lot, happy days & piece of mind.
All done service wise..
a9ffcae11acfa9d0669971bfd2b90c10_zps6ba2
I then set about starting to clean it up, it looks like its been kept clean, maybe by the local hand car wash drowning it in TFR, flat paint, full of contamination, and felt like sand paper. Things like the black trims around windows had all horrible staining on them etc, not good.
Washed it properly to strip it all back..
b932c6d43a3ecc2ecc551bfc4480160e_zpscad2
In short, the wheels need refurbing, look tidy but paints flaking behind the spokes. Gave them a good clean though, literally 3 rounds with various products, and some fall out remover, came up ok for now.
The fall out remover is clear, and turns purple with metal contamination, like bits stuck in the paint.. Looks cool though..
d9ee72305cd7616f7867558c778cc91e_zps3a64
Then went over the car with fall out remover, tar & glue remover and clayed it all, took AGES. Brought it up a lot lot nicer though,
Half the bonnet clayed..
a77f70753cba4fd363e995ef6e5e8a09_zpsb876
Bonnet clayed, wing not..
38ec948d721f52a3235f25d923551133_zps4873
In the sun, it was very swirly, like it had been washed with a scouring pad or something, the colour hid it well, but nowhere near happy, so used the boot lid as a test panel, machine polished/corrected, sealed and waxed..
036aa950026986ef0d180f6403d82122_zpsad07
MUCH better.
After the day of clay etc, chilling with polo.
ECBD4321-8ECD-402D-9720-E73E9A44E524-902
Tried a rotary and DA on the boot lid (as well as debadging it) to decide how to approach the rest of the car and to see how hard the paint is etc. then set about measuring the whole cars paint depth, and then the whole car was machined/sealed/waxed, looks the tits compared to how it was, dead happy.
Bit of polishing (credit to my neighbour for his skills and attention to detail)
4eccf31f037bb24be914805dafb2e5c6_zps08e8
Done exterior..
c5181a01165816aad5eb6911c760ca47_zpsd97d
f32c45074cab7808057bb2ec84ab7c4e_zpsd97e
Bonnet reflection, stone chipped quite bad up front actually, must be from tailgating on motorways etc..
8ca73068997adcc9a561b86d9282f39c_zpsac5c
Washed/clayed (before polishing)
2cf927727c40d9e75f741943935424da_zps85a2
After polishing, much clearer, a LOT less marks, much deeper shine and smooth!
05c060d6dedc981e99e9b642f3422bfd_zps2370
Interior not yet touched, need to recolour the drivers seat bolster also, got a decent supplier for some stuff to do so, but it's quite nice, basic and bland as BMWs are but it's nice.
6fa3105f863156b24f801e26e69799f6_zpsce07
So that's where I'm up to currently, however.
Have some bits on order, and today bought some new wiper blades, discs and pads. Rear pads recently replaced for OEM items, but fronts could do with being changed and discs are a little worn, nowhere near too worn but I like to know where I'm at and I'm probably just being really anal. Also bought a thermostat as I think it's slightly stuck open, hindering MPG so shall see on that one.
Good quality obviously..
ca51079c18ac270c02e0422d6930c190_zps2647
So the wheels will be being refurbished, unsure on colour, maybe just a standish silver colour I think?
Also got one odd tyre to the rest, so will buy one to make a full set of the same.
Already ordered new centres, and the Msport badges for them , will get some new bolts too, makes it look tidier.
Slightly tired looking badges on the car too, so ordered some carbon type ones, still blue and white, just a subtle thing to change.
Don't have xenon headlights so no halos, so ordered some new sidelight bulbs as these ones look a bit yellow and dated now.
Other plans:
Fit an auxiliary/iPod lead
Upgrade speakers, bit disappointed with these to be honest.
Get an armrest centre console and arm rest obviously.
Also may space the rear wheels 10-15mm, but need to check clearance. May also lower it a touch, maybe 20mm front and 10-15mm rear, will do some maths and see what kind of springs I want and see what's available.
May look at a remap in future too, will see how the economy is going, and how much extra insurance will cost too.
Being pretty anal with this, changing things I probably don't need to, but I'm used to making cars as good as they can be at work, it's hard to switch off, and I just like to know where it's all at etc.
All in all a pretty nice car, will do brakes this weekend and hopefully send wheels to be done over the next couple of weeks.
Nick.
  • Replies 63
  • Views 6.8k
Something else to fit tomorrow -
6EACEE77-37AF-4013-BB9A-6AF9CED2B45B-353
Front lower arm bush - common to fail on these.
It's a hydrabush, which contains fluid, they're prone to the rubber eventually splitting, resulting in fluid loss and a large loss of bush rate.
One side of the car was done for the last MOT, but the side that's now gone has failed like a thousand miles later I think - thought this is the idea of replacing things in pairs haha.
It's still got the OE one on, from factory, 110k on it is a good effort indeed. Basically felt it go, car became unstable at higher speeds, steering feel was lost and front end generally feels soggy, coupled with a knock at low speed if you jab the brakes it's probably good to change it really :p
Kind of glad it's failed now, was only a matter of time :)
Right then, had a plan of action today, and executed that.
Firstly set about doing the lower arm bush, as unlike everything else it needed doing.
Dropped the metal engine under tray off - which has a nice little flap in it for getting to the sump plug - how thoughtful. Then dropped down the back end of the arm.
This video explains the excessive movement & thud you get under jabbing the brakes..
http://s963.photobucket.com/user/harrisrac...1bdeb5.mp4.html
Forgot to bring a puller home and couldnt find my big grips or a G clamp to replicate a puller, so took a bit of effort to get it off.
Old and new bushes..
1551CABD-E137-46F9-9E3A-855999C40608-528
Popped the new one on, and bolted it back up..
BDE20F59-CA8F-4BD0-9866-81813E54ED8D-528
Result, a lot less compliance, resulting in no knocks/bangs, wondering at speed & improved steering and steering feel. happy days & a piece of piss to change.
Next I set about changing the brakes, although I forgot to take pics.
Took front discs & pads off, pads still had a good 5mm on them, and discs only had a small lip, nowhere near wear limits, but hey ho.
Cleaned all the sliders up, greased appropirately with genuine BMW brake pad grease and banged them on. - will probably paint the calipers black at some point.
Cleaned the inside of the wheels whilst they were off, as they were totally black with dirt. Only a quick clean but a lot better..
5E6DA832-5658-4CCA-90E7-0194E2DAE330-528
This is why they need a refurb..
1A47623A-65AA-4444-BA53-C55947474EB4-528
Also painted the bell of the brake discs with VHT black to keep them looking tidier instead of them corroding.
A7A3D745-B713-4485-9EA2-E5821A912955-528
Did the rear brakes too, and adjusted the handbrake as it wasnt very effective before, inside of the discs were mainly rust and shit, might explain it. Looks like it could use some shoes soon, but they're literally just for the handbrake.
Changed the fuel filter too, as I got bored last weekend when servicing it, again very easy to do, the more jobs I do it seems BMW really think about people having to work on them.
I then set about changing the thermostat, easiest way was to give myself a bit of room, so removed the engine covers and took the rad fan out the way to gain visibilty and space..
Had to move the EGR/EGR cooler out the way, but got it off pretty easily..
7CAA7EE9-B921-4F2A-8A4F-8C06E24F409B-528
75768189-6440-463D-9923-A860A4CE3D27-528
Did the whole, reassemble most of it, and came to refit a bolt and realised I couldnt get to it, so had to take half of it apart again to get to it..great short term memory me.
New & old stat...both 88 degrees.
9553084E-22EE-44B0-AF5A-B721DCC7D67F-528
Fan cowling thingy has vacuum actuated 'blinds' on it, to aid the rad warming up faster/improving air flow through the rad when its hot, becoming a pretty standard thing these days tbh.
84AA4759-4011-40EC-9393-1425051FB45E-528
Had a devliery or two throughout the day...
New badges came, not changing wheel centres yet, but did front and rear badges.
Front (slight damage
394A2221-3403-49E9-BFD8-0F09E5EF0B4F-528
Some grime..
455F2E59-E14A-49FF-B4FD-A40D1DB64ED8-528
Comparison..
E826225F-7318-4117-A335-767D2EE6B4AD-528
Fitted..
89BC4A9A-25A1-46EC-9A8E-502F3F976B63-528
Same on the arse end, as they're carbon, they're light weight - lighter at the rear = easier skids???
3BCF3DCB-E2CE-4790-B92F-96B8424C39D8-528
38039DB5-1227-41B0-BD9D-877E2B9AE3D3-528
Also, LED sidelights came, look loads better, yellowish ones looked shit.
BEA21804-C972-49E0-80E7-61216430769F-528
15E73298-1BE9-4CCB-A2FF-8A8CC820060A-528
For a 9 year old car I think its aged quite well, dont look too out of place on the road still.
Quick interior shot too - speakers seem to have gotten a bit better the more they're used - weird!
251B1BD3-E3DF-4338-B32C-97ABDEC7257C-528
Gave it a wash, then was gone 9pm, had had enough, so got food..
5719280D-35F6-4B43-94E6-30FFB5384278-528
Now I feel fat and ashamed, however the drive there proved the stat has done the trick, gets higher temp now and stay there, i am intreagued for the drive to work in the morning for effects on MPGzzz.
Ciao x
Edited by harris.racing
Nice work!
Big improvement.
What new sidelights did you choose? - i changed mine, but these, despite having a number of sMD? led's all over, only seem to create a dot of light rather than any of the reflector picking it up.
to be honest i just blindly bought some off ebay in my lunch break, they have about 5 or 6 SMDs on them, look a bit shit looking at them through the front of the light. They disperse light a bit, but i know what youre saying, thats the issue with LEDs, they dont ommit much light, they're just bright..and I'm a poet and didnt knowit.
ill get you a link if you want & some more piccys?
little things make big differences, cant wait to have the wheels done with new centres, M badges, and new bolts. ]
was going to say something else but forgot now. Jelly of yours being a 330d tho, hiya torque
Good progress mate really like it, as for the badge it will either be glass or texalium as carbon is an element it will only ever come in the black/grey shade it is, texalium is used if you want a coloured carbon look with the weave etc as its still pre pregnated and manufactured in the same sort of way.
Random fact for you as I'm bored
Edited by matt-c
Yeah - its some kind of weave anyway as apposed to a printed vinyl, looks better than BMWs interior 'carbon effect' anyway :)
Done more today, probably going to look like iv not done much in pics as its a bit hard to tell, as with the paintwork tbh.
Today was interior clean time.
What was done:
Seats out
Headlining and a/b/c posts steam cleaned
Door cards/dash/centre console steam cleaned
Any leather trim steam cleaned
Leather seats steam cleaned
Seatbelts hoovered + steam cleaned
Carpets, including boot hoovered & cleaned with extraction machine
Leather treated and moisturised, (aircon dries leather - bad)
Carpets fabric guarded
Trim dressed with poor boys interior stuff
Glass cleaned + dealer sticker removed.
Some pics..before...
aeea0368c63dc74dc301ff35b19a5f43_zps0d1e
3d163b895b68c5d98a00ea6891ed552c_zps4476
ee1966eb451ab23d9589d54e92c4f1f1_zpse1c9
547060eb796a32b427a24093957f9b6f_zpsfd0d
ff64533e792518cdebc63af5df941cdc_zpsd2a6
This kind of thing annoys me..
cb556ac7784256bb3810392f398f4c7f_zpsa8b2
Sorted though..
80f573f9261ca80b97a93b3ea264ea46_zps8ea7
During and after..
Mats cleaned
ac4e94eacb32bafe98bd34c025ea3980_zpscbf5
Passenger seat ready to go back in
74fc8e7efcdc5a137a87e553aa75d2f9_zps7e94
Carpets
c809360875307d62fe845bea926f791c_zpsc66f
15cfdeb6b2c430804a3b2477b43a18c2_zpsd4a7
425e9aa19fc6f156e694d81c8a5c53f7_zps2c35
Boot clean enough, just did carpet
b860cf87a3ff1148141e84daff2c83c6_zps0e13
Rear seat back in
f48cbe65573ec4781840ecbb02f79b29_zpse98b
Clean door card
eb59d36f42f30e84b97cd7c93afd3cd6_zpse9a7
All back together..
a5eea7656375f5586ce0e90fd449d3fe_zpsac7c
d3b3dff1b280a9717e7bd59596b7e428_zps4c37
Like I say lots isn't noticeable, but it's a lot fresher in the flesh, just like shit in vents, around the edge of switches etc.
Few marks here and there but 9 years old, carpets are good as have always had mats so that's a winner.
Also got a cutting of leather to send off as a sample to have a colour match made up for drivers seat bolster repair.
Seatbelts etc being hoovered and steamed makes them a bit more supple and nicer too.
Also ordered LED interior bulbs and an armrest and appropriate centre console.
Need to get an aux lead adaptor, and some number plates.
Nick
Also, reference to LED sidelights...
They look like this
303F6932-C81B-4689-9C29-06F4FACFC8A3-146
And like this on
8264BF86-BB65-4AD7-B630-50C3E561983C-146
18C77313-8DE1-480A-83DD-F1A5E5932802-146
So yeah, as you said it sticks in one area of light really, look ok from a distance though.
Not sure on wheel colour, it's a good opportunity for change, but I'm not sure if just a nice silver is ideal, have thought about a dark/gunmetal grey, but not sure with colour of car.
Will paint calipers black too when I sort wheels.
Love it nick,
Nothing better than making a car feel new again :)...
Have to take me for a spin sometime man :)
Cheers dude.
Just came home to a fuck load of LEDs :)
9CEAF1FF-D28B-4159-A429-FC0E98F2806A-468
And stuff ready for wheels, considering buying a new set of tyres but looking at around £600 for a set..
3A95EDB0-CA96-4F3D-AB68-B51A1FEAC4C2-468
Can't fit LEDs ATM though as I don't have the car, boo.
Using other things instead..
1A84F4D0-6040-4680-94C4-26D7F296A82B-468
5A0648B4-469D-4CE8-8C45-AE257572CB12-468
Anyone recommend tyres? Apparently Kuhmo's are supposed to work well, was considering Hankooks too, but I dunno really. Seem about £150 each for branded things like Michilin, Pirelli etc
Siiiick!!
Think you should just stick with silver on the wheels tbh
Or orange :ninja:
I use Kumho KU39's on mine. I rather like them..
Arm rest came today, had to change the whole centre console too, pretty easy really.
417482D6-56B2-4B1A-BAFD-5E129304DDDE-625
757F417E-B191-4731-B8DD-4CCF714CDDB9-625
014AFE4A-27E3-4C95-BA3E-EFB1C625FC06-625
77E1C3F7-87A7-4894-8449-EAC713F63CE3-625
Started fitting LEDs, could only do:
Vanity mirrors
Footwells
Glovebox
Boot
Number plate
As the sidelight type bulbs were too large to fit into the housings, seller sending replacements FOC tomorrow :)
Number plate lights stay on half bright for around a minute. Whilst the canbus is still awake basically haha.
Worst pics ever, look a lot more modern tho :)
84B2BEBF-219B-478F-93C9-3042F3550FC1-625
1EB95F86-160C-42E1-88C6-E0D166BFB547-625
2026FF71-6C72-455B-8A0E-E4020D0596C9-625
I'll take a look :)
You got 225/40 & 255/35?? (18's)
LOl at the vanity mirror picture XD
I'll take a look :)
yep certainly do..
Pretty cheap man. How's the ride & road noise? Wet grip?
Yeah they are compared to Michelin's. I've ran Kumho's on all my BM's and always found them good.
Ride and Road noise have changed from the Michelin's that were on the car from when I purchased it. Wet grip is good too.
What is it currently running?
Erm something like
Aickqciskqgiskqofurhrnem
Received correct LEDs today, all sorted now.
Also received a cheque off previous owner for a radiator, happy days.
Beginning to really like this now, jumped in it yesterday after driving around 400 miles in the polo and was heaven, and the engine is growing on me a lot now iv figured the box out too, so chilling on the motorway, absolute cruiser.
One bad thing is the fact everyone else on the road seems to be a dick towards you just because youre in a BMW, stupid repuation!
So bloody nice man! Really a joy to look at
Been in this myself and can say drives superb !!
So refined but Still gives you a sense of driving ..
Was so nice to get in after beeing kicked in the by the polo all day lol ..
Feels alot more planted than the 320d i drove which had a remap.
Me again.
Nothing too exciting, sorted interior LEDs now, look a lot brighter and more modern than yellowish older type of bulb.
Unfortunately due to the interior lights having clear lenses, the LEDs don't look so nice when they're not illuminated, but still I prefer them.
Front centre light before
A825C8AD-69D6-4B2A-8FDB-664A2579CCC6-232
After (in daylight so doesn't look great lol)
E941AF4F-FCA9-4CA2-B03E-97445310743C-232
Rear courtesy and map light..
45977D94-14F9-4D0D-8AC8-0CF9F8DDF4D3-232
Again after..
41E4BFE5-C711-4CF2-91F9-DCE7AF3AB548-232
General..
294F40D4-08A8-4E38-ACDB-C4BCFDB7BDCE-232
90F71C17-D884-4FA8-B952-90755F8ADD70-232
The courtesy lights still fade out as they should too which is nice.
Gave it a wash in the week, seems to attract a lot of flies.
37F00A4A-005E-4D13-816B-535FB7631CD5-232
A96B23EA-FF2E-4F2B-9A48-834499F48D5D-232
At work... Can't decide on a wheel colour :(
B3A9551A-E29B-48D8-8480-134872A69E7E-232
Also got some new plates..
AAD6D015-395E-4C2A-86BD-77AE4C00A4ED-232
Mmm clean..
1A69163F-2973-448B-B1F0-CB12F5F086B8-232
And fitted, much fresher..
15D6F112-AAA4-4C3F-8765-B83144CEEFB5-232
29062A84-5361-4D07-9E32-7FBB65C0A16D-232
Currently on the look out for some crystal clear LED side repeaters.
Nick
Right was bored last night so had a slight shopping spree.
Ordered:
Some new side repeaters - OEM, which are clear LED anyway, just won't have a yellowish fainted tinge to them
An iPod/iPhone lead for the head unit after identifying what pins I can probe into :p
Rainbow IQ line OEM fit front door speaker upgrade
Currently researching into a rear speaker upgrade, I'd like to keep the standard head unit and not use any amps so just finding things suitable.
Also need to make a decision on tyres, whether to just buy a set of new ones, around £450-£600, or just buy another single "Accelera" I think they are to match the rest.
They're not too bad for budget tyres to be honest, but the road noise annoys me more than anything, trouble is I'll be buying winter tyres later in the year too so just a bit of an awkward decision.
Once I have decided on tyres I'll strip the current ones off and organise getting the wheels refurbished, then build them up new valves/msport stickers, centre caps etc :)
Nothing exciting, but saying that it's a BMW so isn't really exciting anyway but yeah!
