What size wheels do you run?!
I seem to see a huge variety of wheels on polos around here.. from super wide 13's, average size 14's, minilites, 9j, etc etc! Wanna know what people are running, what you had to do to make them fit, how low you've gone.. etc, etc, photos for something interesting :D
I'm currently running 15x6.5 on 195 tyres which doesn't seem to happen very often.. have had to roll (but not flare..) all 4 arches, 3mm spacer on one wheel at the back (closer to the strut than the other?). Currently lowered 60mm at the front and standard at rear on standard shocks... going lower in two weeks with uprated shocks though.
Let's see what you've got :)
  • Replies 11
  • Views 785
I have the factory size, the original wheels for my car. They're 5.5x13 et38.
They work, they fit properly, they don't need special bolts, adaptors etc they fit properly. They don't foul the brakes or body.
I did run a different size once, a perfectly suitable 6x14 et38 but they didn't feel right. Tyre size I think was the main problem (185/55-14).
I also run 13x5.5 et38 VW rims. Tyres are 175 60 13, as they are close to original rolling diameter. I wanted a little wider than standard, and didn't want very low profile as it's a daily drive and I like to retain some comfort. I put 5mm spacers on the rear, as the breadvans wheels always look slightly lost in the rear arches, especially when lowered. Arches had to have a little hammering, but nothing major.
14x7/8 tyres are 195/40-14
Mk2 Polo Saloon
13x6 BBS Mahle
15x7
Tyres - 165/50/15
13x5.5 bbs RA for the OEM look.
its a bready, best option is to cut, weld and smooth the rear arches.
all tyres are 165/50/13
13x7 Mk1 Golf banded steels
Mk2f Saloon
14 x 6 et 38 , will have some 14 x 6 et20 soonish
15x8 all round et25
mk2f
15x7 ET21 15x8 ET9
Fourteen times six
