OEM retro blaupunkt audio
blaupunkt acr 3251
pull-out unit (so you take the whole radio with you!)
4 x 10 watt speaker outputs
bass and treble controls
tape unit has been cleaned and tested, sounds great!
fm/am/lw RDS radio tuner
Supplied with code and print out of user manual
includes fitting cage with iso sockets for plug and play fitment
£30 inc post
£25 collected from chipping norton or oxford airport
blaupunkt cambridge sqr 39 in great condition. Recently had the tape head cleaned and any dust blown out of the casing. Tape motor is a little noisy, but with the unit set to play at a fairly normal volume, you can barely hear the motor, if at all. The buttons function as they should. Fairly basic by modern standards, so doesn't have any line outs or ins.
2x10 watt rms or 4x5 watt rms on board amp
4 speaker outputs on old style 2 pin dins
No iso sockets, so a bit of knowledge will be required to wire this unit in (I am more than happy to help with advice on this)
fm/mw/lw tuner
backlighting works
no code required and supplied with fitting cage
Std fit in a lot of old 80s mercs, but would look great in any 80s classic
£30 collected
£35 posted
Edited by g40jon
  • Views 373
Blaupunkt boston cc22 stereo cassette car stereo as fitted to a lot of early 90s german cars. Std fit in vw polo gt and g40 models made between 1991 and 1994. also found in some bmws and audis.
Made in 1994
Code is written on the top of the unit, although I have currently turned the code off, so shouldn't be needed (this is done by powering the unit up, whilst pressing buttons 1 and 4)
unit powers up, radio works, casstte deck works perfectly
tape head recently cleaned
backlighting all works
4 speaker outputs, 5 watts rms per channel
balance and tone controls
printout of manual and fitting cage included
It is a pretty basic unit, it does not have any pre-outs or aux in, so you won't be able to connect plug and play amplifiers or cd changers to it. It is in generally good condition.
£20 collected
£25 posted
BQA 107 power amplifier, perfect for adding some grunt to your old blaupunkt head unit.
4x25 watts
din inputs and outputs
no crossovers, it is purely a power amp
£50 posted
£45 collected
