1.0 radiator on 1.3 gt engine
Can I use my 1.0 rad on my gt engine?
  • Views 524
Pretty sure they are the same across the range? If anything was different it would be sensor related, but fitment would be the same.
think the GT and G40's have 2 speed fans.
There are a couple of different width radiators, 380mm, 430mm and longer radiator cores.
I've used a tiny 380mm core rad on my G40 turbo with no ill effect, so using the 1litre rad should be fine.
