polo mk2f/3 coupe jacking problem?
Hiya
Basically wanting to jack my car up fully then use axle stands so its safe, i have found a perfect place for the axel stands to go at the rear but I'm struggling were to put them at the front, i have heard people say under the anit roll bar mounts at the front of the car but i want to take this off and work around this area so this is no use. i have tried in a few other places but does seem very safe.
Looking for advice were to place them ?????
thanks
tom
  • Replies 8
  • Views 730
Along the sills there are little indents that mark where the strongest parts of the sill are, these are the main jacking points on the car. There's one on each side for the front and rear.
You could jack the car up on the arb mounts and place the axle stand under these sill markings to drop it on. Just be careful cos these can get chewed up pretty bad.
Cheers thanks for that ill give that ago
thanks
tom
Use something soft that will deform under the weight, or a piece of wood with a deep groove in. If you don't, you may damage/bend the seam on the sill.
I personally place the stands under the rear TCA mounts when getting the front up, again with something soft
Personally I use a flat piece of wood placed on the axle stand and put them on the flat jacking point at the front (not the sill) FOr the rears they go on the rear beam/mount point
I have used a single axle stand under the engine mount in the center of the car where is balances really well and gives you complete access to the whole suspension system :)
Balances is not a work I want to hear when working under a car
I gave the car a good shove and it wasn't going anywhere :p
