Mk2 headlining
As above really, am i right in thinking the saloon and coupe headliners are the same, as are the A, B and C pillar trims? Damn I wish i had kept the black lining and trim from that coupe I broke!
  • Views 1k
I recon the coupe might just have enough material for a loon, but definately not vice versa.
How'd you reach that conclusion Mikey? I'm guessing the roof sizes are the same, it's just the C-pillars?
Si, take a look at 86Cs build thread titled 'Wide Arched Saloon'. He put a black Coupe headlining in his and used off cuts for the rear pillar.
The only pillars lined with the same stuff are the rears, the coupe has broader inner C pillar panels it seems from interior shots. The sections are seperate, and plain vinyl as used on the other pillars would probably look as good. So the reach over the back window is probably the priority.
Vinyl might work as the a and b pillar are vinyl type trim anyway
