sold !
bottomviewbikecarbsandmani_zps72d5e710.j
Fits AAU, AAV, GT mpi engines ect
£220 new plus postage from bogg bros
I want £150 minimum posted , they truly are works of art, light alloy, looks as new
I'm in hull
text me 07853933318
see my build thread for photos oakgreenpolo
Edited by dart_strife
  • Replies 9
  • Views 285
why you getting rid already mate?
as iff you haven't seen my posts bro !! abd bearing went on the crank at 140 k. so i now have me an afh, need both manis again as afh
interested in my lightened afh bottom end?? will do you a good deal, it has all been rebuilt
well I've just got an afh the other day, so it would have to be pretty cheap
£180 is the lowest i want to go mate, its such a bargain!
What Did you replace ? How many miles had it done ?
Copied from my ad:
block inc internals:
This made a massive difference to the speed that the revs would go up and down!
standard 16v block cleaned and painted black
honed cylinders and new rings around 2000 miles ago
new big end shells and main crank shells about 3000 miles ago
lightened and balanced rods
lightened and balanced crank
nearly new oil pump
timing belt tensioners only have around 5000 miles in them
i will also include a top quality gates timing belt with only 1000 miles on it!
i never changed the waterpump as it still looks in great condition
lightened and balanced flywheel
i shall not be including the clutch as this will be swapped onto my new engine
£200!!
collection only from leeds LS5 3PG
craig - 07846992735
Edited by dubownerbilco
bogg bros mani
here is a current pic , taken off the engine, comes with fairly new mani gasket
Sold to smithy !
