lots of parts to sell at the show..
time for a big clear out..
all colected at the polo show. wood like 50% deposit for the big things coss dont wont to bring them all the way down and get messed about.. open to offers on every thing just send me a pm
set of seat 15inch wheels all center caps and good nic. 3of them have snow tyers on. grate for the winter.. £100
tim volt meater.. £14
mk3 cam cover £5
mk4 side repeters £3
g40 air box cover bit.£5
mk4 se standered wheel (no tyere)£8
central locking kit never used. £14
got a gt head/ block no cam thow. £20 for the head £20 for the block
mk4 head light swich with fog lights £5
mk3 glove box lock. if you give me your key i will make it fit the lock so it locks it. £10
wiper relay so you can ajust the time of the intamitent wiper. grate on eny mk1,2,3,6n,6n2. £5
seat belt pads. 4of them £15
mk3 tow bar loom £10
g40 oil pipe. good for a spair £5
sony 250w 2chanle amp £15 have a loom as well if you nead it
k&n air filter for mk3 polo (will fit in the 6n air box as well) its a round replasment filter £15
mk3 seat belt holder things.. £8
g40 look tail lights. standerd ones that have bean painted. dont look to bad. £10
2 gt steal wheels both with tyers £15 the pair
g40 intake pipe £5
g40 knock sencer £10
mk3 polo end plates off bottem end £5
flexy pipe, had this made bwhen i had my g40 turbo its a 50mm pipe with a flexy on it, shore some one cood use it for somthing £10
electric window swiches, for a mk3 goes in the dash below radio (have to take out heated rear window swich £10
tim oil gauge have sender as well £15
gauge holder £5
cold air in take(cut out fog light hole)£10
had this on my g40 turbo.air filter. £15
cd changer and all the leads £15
gt square back bumper £15
polo paper work. what you nead?
mk2,3,6n,6n2 hid's £15
jacket hanger fits to back of head rest. £4
heated jets £8
loads of relays. from lots of difrent vw's. 50p each
mk3 rad top caps. hold the rad in. £1 the pair
i have boxes of random mk3 swiches,dash blanks,what you nead? i probely have it..
mk3 smooth boot. £50 sorry only photo i can find.
boot relese. will fit a mk3 but cood make it fit a 6n or 6n2 £3
g40 co2 pot £8
6n role bar from a diesel. comes wit all mounts£10
bmw firstaid box (empty) same size as polo one.. £4
hela brake light£4
floor mats£4
manual boost controler £10
cant remember what tis is called, used on g40turbo hope some one can help me out? £10
mk3 fly wheel £5
also have 2 mk2 haynse manuals £3each
  • Replies 23
  • Views 3.3k
shotgun heated jets!
Hello Mr. Keir,
I'll take both dark mk4 side repeaters and the "33"-Relay.
And the antiroll bar, is it from the 6n1 diesel or 6n2?
And what about the diameter of it? Is it 18, 20 or 22mm ?
cheers
Christian
Edited by Christian6N
its off a 6n diesel. i am prity shore its 22mm..
ill take the coat hanger, elec window and boot switches ross
will send you a pm chris..
Ok, so for me just the relay "33" and the side repeaters. Thanks a lot.
Ill take holder and oil gauge :)
you shore you dont wont the volt one as well :nod:
haha ..
Its abit pricey for me as i've got no need to have one tbf bud :(
If you sort me a deal out for the 3 i may be tempted.
Was gonna offer you 15 for gauge and holder..
So would you take 25 for the lot :)
£28 for both and the holder and you have a deal :-)
tow bar loom please :)
If the above doesn't have the boot switch ill take it
Okayyyy .. pulled my leg lol . !!
Reserve them me and ill get them off you at polololol show :)
Air feed please chap. Maybe interested in manual boost switch too. Gotta check funds.
and the bit you couldnt think of is a boost pressure switch ;) (replaces what switch)
cool. i no you whire it in to the throtle body
should be set to 6psi too ;)
How much for air filter, cold air feed and manual boost controller?
£30?
Sounds good to me ;)
mk3 seat belt holder things.. £8,
I'll have these Ross but you'll have to remind me on at the polo show ;)
Co pot mate posted to sheff, price dude?
£11 posted?
i dont suppose youd happen to have a g40 rocker cover in your endless pile of parts hahaha.
no sorry
