afh 1.4 16v haynes manual
i dont think the afh 16v is in the red mk4 polo haynes manual, or prove me wrong , any one have a haynes with the afh engine in it ?
  • Replies 11
  • Views 682
Don't think it's in any of them!! definately not in the RED 94-99 one Might be in the 99 Seat Cordoba???
Edit: Not covered in the Cordoba manual either!! All covered in ElsaWin :thumbsup:
What is elswin bro ?
It's the programme VW use that tells them how do do each job iirc. You can download it I think, or buy a hooky copy from ebay
there is no Haynes that covers the AFH mate
so does any one have the timing up diagram?
Also were do I get the torque settings ect ? Head bolts ect
This is all great , and am in the middle ot using these guides , however the crank pully, do I align it to 2v or 4v?
It's a four valve head (4v) so
So new belt an pulleys are on , want to know iff this is normal . Tensioned up the belt with the puly and tightened to 20 nm . I turned the engine over twice , all seemed ok how ever the tensioner pointer moves back then forward to were it should be set , is that correct ?
