Cloudy 6n2 Headlights
Right, my headlights were a little cloudy and I've had a 3m restoration kit on my desk for quite some time. With the little sunshine today, I thought I'd do them with a few other little jobs I've been putting off.
The kit is excellent and I have lots left over. Highly recommended.
Before:
After
45 minutes and a hand held drill per side.
PoloD.
Edited by PoloD
  • Views 1.6k
That's not bad at all. Was it just a case of using a mop and polish, or did it need sanding down first? I ordered a kit a while back but it never turned up. Didn't bother getting another.
Is that water on the out side, or inside?
Hello,
The 3m kit contains everything: green tape, drill adapter, sanding discs, polishing compound, instruction leaflet.
It's a fairly easy process too with the drill doing all of the hard work of sanding in various grades and then polishing, so I can't really complain. I had a plant water bottle with me to keep wetting the area as I sanded and polished with the drill.
In fact, I used a battery operated drill and nothing fancy!
The water in the second photo is on the outside (note bucket in background and wet tape) and the lights looked even better when dried with a chamois leather.
Anyway, this is a job done by a non-professional i.e. me and I've got enough left over to do the process for another 2 headlights.
PoloD.
Edited by PoloD
