G40/VW2 Calipers/Discs/Pads/Lines
Hi, I have for sale a full G40/VW2 brake set up. The disc's have had a little use but no much, the pads are brand new as are the lines (all good quality standard parts from a respected motor factors). The calipers have been cleaned up and are in good conditon. The bleed nipples have been removed and are about £3 each from the stealers (I called willenhall coachcraft to confirm they can supply them) so no hassle with snapped/threaded/jammed bleed nipples which is a common problem.
This set up owes me about £90 in total, would let them go for £75 posted. Would also swap with cash for a 4-2-1 for an 8v mk2f
  • Views 328
No interest?
No interest?
I pm"d you said id swap the brakes for my mani if your willing to courier them
I'm interested if not already sold?
Where are you ? I can collect if your not a million miles away
SOLD
