6n2 1.0 EGR valve
hi i have a 1.0 6n2 and had an engine warning light come up so had my mate put it on dino and it say that its the egr valve but when i have been looking to buy a new one i cant seem to find one for a 1litre the smallest engine i can find is a 1.4, does anyone know where i can get one from?
  • Replies 8
  • Views 8.2k
Take the EGR Valve off (2 minute job) and get the part number.
Stick that part number in eBay and you should find one.
Try both combinations of the part number though ie. with spaces and without spaces between the letters/numbers
You might even be able to see the part number without taking it off.
*EDIT*
Looking on eBay, with the compatibility checker you get on some listings, the 1.4 will fit on a 1.0
If you get the part number I can check it against one i have lying around in garage which died on me a few month back from a 1.4
Edited by curty409
030131503F exhaust recirculation valve / AUC
From your local VW stealership or TPS if you have one near you, You might find one on ebay if you search with that p/number
just been to see how much one of the egr values are and they want 160 for one, so thats a no haha but i have hurt you can take the egr valve off and clean them? does anyone have any idea how to do this?
cheers
#4 8Nm
#6 10Nm
#7 8Nm
#8 Renew
Unbolt it and spray it with carb cleaner and as far as possible with an old toothbrush.
If you put 12v onto pins 1 & 5 of the valve body, you should hear the valve click
cheers pal will give this a try and see if it stops the problem
Also check fuse #30 5 Amp as it supplies the power to the valve
cleaned one last week on an astra diesel. very easy to do as nige8021 said. after you finished you will need to get the error message delete from the ECU. as dash light may stay on til the error deleted
Edited by residentmelon
  • 3 years later...
The price you quoted is a little dear. Euro Car Parts sell them for less and most branches will carry stock of the OE part and an aftermarket alternative (HAAS) and will price match too.
