Mk2 polo hoses and grill
I'm after the two hoses that go from the stat housing to the inlet manifold one goes to the in,et and the metal water pipe and the other just goes to the manifold. I also need a throttle cable for a pierburg carb
The car a mk2 84 with a an 1.3 mh engine fitted
Also a front grill doesn't really matter if its a single or twin lamp as will be used to make a de badged one so clips and damage to the outer part don't matter
Thanks Matt
Edited by mattieboi6n
  • Views 481
I have a grill in Banbury
Ideally would be nice if local to me (Bedford) but if you would be willing to bring it along to polo show I would have it. But I need the pipes before I can get to polo show
i can mail you a section of a broken grill, i saved it for the same reason.
that would be perfect i would cover the cost of postage. and i take theres enough to replace the badge.
about half a grill, i'll split it and post you half,
PM your address and i'll be posted saturday.
Pm and thanks mate
All sorted now thanks guys
