Spraying a MK2 door
Hi there my drivers door on my MK2 got crunched recently and so has lost a bit of paint. I've popped most of the dents back out, but I'll still need to use some filler to correct some of the rough spots.
Anyway, the question is, is it sensible to paint it myself and if so whats the method?
-I have only a little experience spraying.
-my dad has a workshop with a proper spray booth and all the tools I could want. (and a little more experience spraying than me)
If that sounds ok, what paints to I need/ are the best for rust prevention etc...? My paint is LA5Y Helios blue (METALLIC). Does it make a difference that I'm spraying with metallic paint? Guess not.. but...
cheers.
  • Views 1.2k
Trial and error, if you mess it up you can always sand it off and start again
its all in the prep Sanding with different grades and wet and dry.
A good eye
cutting compond
polishing.
Quite a few guides around the internet
Just on example.
A good eye
cutting compond
polishing.
Just on example.
when you say cutting compound will meguiars ultimate compound do, or am I being thick?
Your dad has a workshop?.... So why don't you ask him!
