6n2 window nightmare !
hi peeps need some advise asap my driver side window is driving me mad it keeps falling off the runners like A plastic clip with a lug onit that sits a hole on the metal bracket that holds the window i have tryed loads of things to hol it on nothing works with the hot weather here FINALLY !! i need to window working it comes down just as soon as it gets half way down it just falls to the bottom : / there must be somebody who has had the same prob
hellllppppp !!
Edited by dels_concept_gti
eBay item: 190498848076
Remember to buy the right side (drivers or passengers)!
Just replace both and white grease everything when you are there.
PoloD.
i have the same problem but mine is on the left hand side! still need to find clips that work and fit!
Like polod said, new regulator clips off ebay, mean time before they arrive, cut the lug clip off (the part that holds the metal brackets on which could have partly snapped anyway) so your left with just a hole, metal bracket over the whole your left with, use a washer, screw on and that will do the trick, even with a bit of super glue for extra strength. If that makes any sense.
