please delete
As in the title , I'm after a brake servo and master cylinder , the 22.2 cylinder , iff you have any that's fine too as I can get the cylinder on its own at £28 new . But the servo I mainly need , I'm in hull thankyou
07853933318 Andy
Edited by dart_strife
  • Views 453
i dont think the servo fits. think its only the 22mm master cylinder that dose..
You will want just the 22mm m/c from a golf, and the biggest servo for a polo is a gt/g40 one
Ahh I c , well I will buy the new master cylinder , look 4 a bigger polo servo . For the Vauxhall front brakes do I still use my polo brake hoses ?
no you will nead vauxhall ones i think. and the 1L servo is bigger than the g40 one eny way (nothing you wood notice).
have you got the bolts you nead to put the vauxhall brakes on the polo? i have a new set if you are intrested.. just send me a pm
I do bro , I have
Astra gte calipers and carriers powder coated gold
The correct bolts
Big red repair kits
Big red pistons
Vw golf discs and pads
So need astra hoses
Vw golf 22.2 master cylinder
New banjo bolts bleed nipples
