Weber DCD
I bought a Weber 28/36 DCD carb ages ago, to fit to my MK2. Who else is running this carb? I'm just wondering what sort of set ups people are using, in terms of venturi, jets, adaptor plate etc. I've accidentally bought a 1.4 8v (silly me) to fit, so wondering what would be best to run on that.
Thanks in advance
  • Views 1.2k
maxgt has one on his 1.3 jetta
Standard jetting might be pretty close if the one you have is from a cortina - the engine size is 1498cc
The only way to find out is to experiment/pay someone to jet it for you
It's from an 998cc imp lol. I was originally gonna use it on a 1043 I've researched the jetting for that lol.nif someone's got one on a 1.3 it should be pretty close
The jetting for the cortina is
Venturi 26/27
Aux venturi 4.5/4.5
Main jet 140/155
Air correction jet 230/180
Emulsion tube jet F30/F30
Slow running petrol jet 50/70
Slow running air jet 200/70
Progression holes 2x120/1x120
Starter petrol jet 190
Starter air correction jet 100
If that helps at all
(I have a cortina too)
Venturi 26/27
Aux venturi 4.5/4.5
Main jet 140/155
You're awesome, I was gonna research that today but you've saved me a whole lot of time. Cheers bud
No problem dude glad to help :smile:
That's for a Cortina 1500 GT (actually 1498cc) which had 78BHP. It used a 70 pump jet. Not great for fuel at high load.
Smaller and you can get a bog.
Simca 1500 (actually 1475cc) had 81bhp. It used
Venturi 25/26
Aux venturi 4.5/4.5
Main jet 135/140
Air correction jet 205/150
Emulsion tube jet F33/F33
Slow running petrol jet 45/70
Pump jet 50
and ran with 6.5 float level versus Ford's 5.0.
Clever Frenchies.
I've been in a passenger in both - though with different drivers - and I preferred the Simca. Admittedly the Simca car was perhaps better maintained and the German driver in the Simca was probably more of a nutter.
