Stub axle spacers - MK3 10mm
After a pair of 10mm stub axle spacers for a MK3 (pref with longer bolts too)
Could do with them asap
Anyone got any or could make me some? Drop me a PM
SAFE!
  • Replies 12
  • Views 568
Iv got two 5mm ones I think?
I've got a pair of 8mm if any good to you?
8mm probs perfect tbh haha
PM incoming
I've got various thickness ones and can get you bolts if you like :-)
I got some off DKnight
http://www.axlespacers.co.uk/
FYI 10mm each side is about the limit on the standard handbrake mechanism's cables, but it depends how worn your rear brakes are (more wear = more clearance).
same I'm after some stub axle spacers 5mm-10mm alloy perfere pm me what you got with prices please
or email me fotos with prices g40dabbsy@hotmail.co.uk
I'm running 15 a side with brand new rear discs/pads. Old style hand brake mind so maybe that helps? Or is it the discs?
I'm running 10mm a side on mine with a disc set up, using mk4 golf calipers and had no issues
Yeah could be, this is on my late mk2. My early mk2 just has wheel spacers on it.
If someone can tell me the measurements, pcd of the holes etc then I may look at making some of these up. DKnight is doing them for a very good price though with bolts.
Think I'm good now, having seen wheels fitted on another mk3. Will test fit wheels on mine tonight and see
