15x7 et20 on MK2F Coupe?
Seen some wheels i like. They are staggered. Fronts are 15 x 6 et35. Should be no problem there. Rears are 15 x 7 et20. Would they scrub on a car lowered 60/40? or 60/50?
  • Views 855
Depends what tyres you go for ... If personally run 165/50s on the rears and that'll be fine
Edit at that night you may be able to run a wider tyre 195/45?
Edited by matt-c
Forgot to mention i dont do stretch. A tiny bit is fine, but i actually like to corner quickly. I was thinking 175 50 all round?
Probably.
14x6 et33 catches on mine, with 185/50
Actually et23 forgot 10mm spacers, so you'll have like 15.7mm more poke than that rim wise, 175 will give you another 5mm in theory, dunno really.
Cheers Nick. Wont be buying those wheels then, cant be doing with scrubbing or slow cornering, as good as they would have looked. For reference these are they (centres would have gone back silver) Lips are the shiniest thing i've ever seen :shock: :
http://www.ebay.co.uk/itm/161042593647?_tr...9#ht_154wt_1300
Remember I'm lower though mate, so you'll have further to go suspension travel wise before a catch - although yours will catch sooner due to more poke..not sure what rate springs come on the decent lowering kits youre after mind.
Well I have 165/45s on a 6 and there barely even stretched and that gets alot harder corners than a 1.0 lol only a suggestion could easily be done with two tyre sizes which is exactly what I've gone for
