Mk 1 Golf wheel arches on 86C coupe
Next week we'll do the fender job.
I bought both fenders new, will buy the rear repair arches too.
Cut the arches only from the Mk 1 fenders, and replace the Polo's arches with them... or I saw someone here who welded the arches over the Polo's arches...
Any advice or experience is appreciated on how to...
  • Views 1.8k
Uh, don't understand why you would weld them over the polo's arches?
Is the point not to allow wider wheels?
they aren't welded on top of the old arches they are welded over them to extend them and the inside is cut off so that its still single skin and the golf extension bits become the actual arches
I Had front arches the same as that on my bready too but I also did the rear arches to match using the rear golf repair panels
Golf wheel arch is actually wider to, so to fit them and keep things proportionate you will need to chop down the golf panels aswell
Finally done.
Almost straight fit to the Mk2, but needs quiet a lot of work to put on the Mk2F ( bumpers! ) ... but worth every penny and time put into it.
Did only the front, as the rear needs definitely more time if done properly.
Edited by ZoleeG40
