seat subframes
I have some bucket seats but cant find any subframes that fit straight into polo coupe gt. I've read through some things on here but nothing seems to be any help. Can anyone help please. Links to websites that sell the right subframes or anyone knows how easy it is to remove the ones on the current seats and fit them. Thanks all.
  • Views 936
Try searching for mk1 golf fitment or mk2..
There the same :)
Fitting the ones on the current seats to something non standard looks awful from every attempt I see as they are too high.
Its easy enough to chop it weld it up and make your own custom frame if you know someone with a welder
I used a set of 6n bucket seat frames and chopped and welded them slightly narrower, as the rear sliders are a bit wide. Standard runners are welded on, can be chopped with an angle grinder but as mentioned they sit a little too high.
IMG-20130611-WA0009_zps36af6d80.jpg ;)
will get some pictures of the subframe tonight :) Still needs abit of a tweek
Thank you everyone. I just cant wait to get them in!
